Question about Zefal Genesis Raptor Floor Pump with Gauge
How do i take off the nozzle for the genesis raptor air pump?
I am trying to take off an attachment that (i think) was put onto my floor pump. the attachment does not fit in the bike tire I need to pump up. i am trying to take off teh attachment so it is just the air pump nozzle.
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Dec 05, 2014 | Kirby Vacuums
I have a Ruud Model UBHC-17J11NFD in my basement. Water is coming from the bottom of unit and pooling onto the basement floor. What should I check first?
Hello, most likely you have a clogged condensate line, in order to clean it you will need a wet/ dry vac and attach it to the outlet of the line and the suction pressure should dislodge the clog. Also, if the unit uses a condensate pump make sure it is working, if its not it can cause water to pour out onto the floor.
Aug 09, 2011 | Ruud UBHC Air Conditioner
I bought a serfas bike pump some time ago and am not sure how to attach it to the tyre. Whether the lever is up or down, it does not attach and slips easily when pumping. I seems wrong. please inform of...
generally you have to put the pump up to the nozzle and have the lever down then put the nozzle in tightly and then pull the lever up. If after several attempts it doesn't work the pump may be broken, as bike pumps generally break easy
May 03, 2011 | Serfas Cycling
I can't get my pump to pump air in my daughters tire. This is my first time using a pump where I have to set the pressure. What do I set the pressure to in order for it to pump the air in the tire?
You don't have to "set the pressure", that knob is just for your own reference.
Most problems of this sort are due to not getting a good seal with the tire nozzle. Here are some steps to help you along.
1. put the bike on a flat surface
2. spin the wheel so the nozzle is facing upward
3. put the pump end on the nozzle with the lever down (this is a common mistake as older pumps had to start with the lever up)
4. Push the end down on the nozzle and pull the lever up
5. If you hear air escaping, then hold the pump end on the nozzle for the first few pumps.
6. pump it up till its a bit hard but be careful you can pop it.
check out the video for a but more info and good luck!
Mar 17, 2011 | Zefal Bicycle Air 1 Floor Pump
I don't understand the way the lever works when you place the pump on the tire valve to inflate more air. Is it supposed to stay in the down position or the straight up position to lock it on the valve...
Before putting the pump on the valve turn the attachment so you can observe inside it. Move the lever back and forth. Observe at what position the lever causes the fitting to constrict and hold on to the valve. That is the position it should be in when you attach to the valve. I'm not certain but I think you will find that the fitting is able to be used for both presta and schrader valves without adjustment. Just put it on and fasten with the lever. The seal is then established.
Oct 03, 2010 | Blackburn Air Tower Floor Pump
I can't put gas in my car without the pump shutting off every five seconds. I think the metal flap where you put the gas pump into the car fell into the line. what can i do to get it out?
On most modern gas pumps there is a sensor in the tip of the nozzle. When it feels to much pressure or liquid it shuts the pump off. When you are filling your tank you need to leave a little room for air to come out. Try to not put the nozzle in as far and see if that will work. You will only need to leave a little bit of room. Hope it helps!
Jun 21, 2009 | 2003 Toyota Corolla
1999 Pontiac Grand Am Fuel Problems
The gas guage has a sending unit in the tank attached to the pump, there is a small circuit board on it that has smal"fingers" that send the signal to the guage.These get worn off and thus sends a false reading to the gas guage in the dash. The gas tank must be removed and a new unit put in to solve the problem. I had to do this repair to mine. As for the gas issue, just try pulling the nozzle back out of the filler neck when putting gas in, sometimes the overflow tube gets plugged up and won't allow the air to escape as the gas goes in the tank, making the gas pump think the car is full, pulling the nozzle will allow the air to escape. Hope this helps.
Mar 08, 2009 | 1999 Pontiac Grand Am GT
Bissell 8930 Pro-Heat wont dispense water/cleaner onto floor, but attachment works fine.
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
Jul 21, 2008 | Bissell Vacuums
Dispensing problem w/attachment and maybe floor partion
The F5914 has a hose that must be attached to the pump when using the upholstry attachment. Make sure that the solution hose is pushed onto the pump valve all the way. Try pushing the hose down and then pushing the locking collar down to secure it. This will insure that the hose is fully engaged.
Jan 21, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover aquamaster
sounds like you need to attach the air hose
with reservoir in place you clip on the lid with tubes attached, one of them goes down to the floor cleaning nozzle, the other tube should be about 20cm long with an end piece,
this is the air hose and it fits into a small hole under the reservoir on the motor housing (the heavy mains powered part that clips onto the big recovery drum that sits on floor)
it's mentioned briefly in the manual, here it is in pdf form http://www.box.net/shared/rnh39ffjcq
Nov 03, 2007 | Vacuums
Zefal Genesis Raptor Floor Pump with Gauge Logo
110 people viewed this question
Top Zefal Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
