Question about Yamaha RX-V861 Receiver
My rx-v861 Yamaha reciever sound cuts in and out while watching my direct tv
SOURCE: Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Posted on Sep 12, 2006
SOURCE: yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Posted on Jun 12, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
SOURCE: Direct TV remote code for yamaha rx-v463?
It is 30376. The trick to discovering, is to turn the receiver off, first. Then it will power on when you input mute/select 30376. Then you can program the DirecTV remote to adjust volume (in AV2 mode only or in all modes). However, it will only power up the receiver. It has to be turned off with the original remote or at the receiver itself.
Posted on Feb 22, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Posted on Aug 23, 2009
No volume from surround sound system on dtvcbl cable, dvd or cd modes with yamah rx-v861 powered on.?
Have you looked at the manual? How did it fare using the set up test tones? Did you assign the digital inputs?
http://www.retrevo.com/support/Yamaha-RX-V861-Receivers-manual/id/2526ci757/t/2/
The unnamed sources probably have manuals, too.
Apr 26, 2011 | Yamaha RX-V861 Receiver
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Nov 17, 2008 | Yamaha RX-V861 Receiver
Losing digital picture with HD TV
First, hide the remotes so that the TV cannot "see" it. If the problem goes away, it's the remote. Other than that, it sounds as if the receiver is faulty...accordianman
Nov 02, 2008 | Yamaha RX-V861 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
May 14, 2008 | Yamaha RX-V861 Receiver
Hooking up playstation 3 to a yamaha rx-v861
have you set your toybox to the appropriate settings for the TV??
Jan 11, 2008 | Audio Players & Recorders
Yamaha RX-V861 Receiver Logo
49 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
