Question about Bosch Dishwashers
Dishwasher fagor flash led - Bosch Dishwashers
I need some help on how to start Fagor refrigerator
Fagor Refrigerator manuals
Which Fagor model is it?
The link above is for free manuals for many Fagor models.
Feb 19, 2018 | Fagor Dishwashers
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
No instruction manual
The instructions are available in
http://www.fagor.com.au/manuals/dishwashing/versionw/FI-48W,%20FI-64W.pdf
Hope this helps. Please post a comment to say if you found this useful or not.
Apr 20, 2010 | Fagor 24 in. FI-48W Dishwasher
Fagor Dishwasher FI-48w Replacement Parts
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Jul 04, 2008 | Fagor Dishwashers
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Dishwashers Logo
12 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
