Question about Fujitsu Office Equipment & Supplies
How to take pick roller/Eject roller off fi-6130
3 Suggested Answers
TechSatya
  • 104 Answers
SOURCE: Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Posted on Jul 27, 2010
Testimonial: "Hello TechSatya, The information you have provided is very helpful. We can now notice staple-pins stuck inside the Sensor panel. Thanks a lot."
  • 643 Answers
SOURCE: Hi, I have a
  1. Turn on the scanner, and confirm if it is connected correctly to your computer.
  1. From the [start] menu, select [All Programs]?[Scanner Utility for Microsoft Windows]?[Software Operation Panel].
  2. From the list on the left of the panel, select [Device Setting].
  3. Click the [Clear] button beside the replaced consumable.
  4. Click the [OK] button on the displayed confirmation message.
Posted on Jun 22, 2011
How do youfind scan count
If the scan count of your fi-6130 scanner exceeded 2,00,000 scans, then you may have to replace the consumable parts. After replacement of the consumables, you need to rest the consumable counters. To check/reset the Pick/Brake Roller Counter, please follow the steps provided below:
1.Turn on the scanner, and confirm if it is connected correctly to your computer.
2.From the "start" menu, select "All Programs", then select "Scanner Utility for Microsoft Windows", then click on "Software Operation Panel"
3.In the dialog box displayed, from the list on the left of the panel, select "Device Setting"
4.Click the "Clear" button beside the replaced consumable under "Page Counter"
5.Click the "OK" button on the displayed confirmation message. The counter is reset to 0
6.Click the "OK" button to close the "Software Operation Panel" dialog box
Thanks & regards,
ScanCare
Jun 04, 2014 | Fujitsu fi-6130 duplex scanner
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Thanks & regards,
ScanCare
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
Scan multiple pages
Hello Chris,
Please check the followings:
1. Are the multi-feed conditions and paper quality requirements satisfied? - Please confirm whether the documents satisfy the conditions described in "Multi-feed detection condition" and "Document quality" of Error Recovery Guide.
2. Did you fan the document before setting? Has the document just been printed with copier or laser printer? - Please reduce sheets of the document or fan the document 3 to 4 times to remove static electricity.
3. Is the thickness of the bundle of documents less than 5 mm?-Please reduce the number of sheets of the document to satisfy the condition.
4. Is the Brake Roller dirty? - Clean the same
5. Is the Brake Roller set properly? - Please install the Brake Roller correctly.
6. Is the Brake Roller worn out? - Please check Brake Roller and Pick Roller counters, if the recommended cycle has exceeded or if the Brake roller is worn off, then please replace the Brake Roller.
If the above information doesn't help, please contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Thanks & regards,
ScanCare
Aug 21, 2013 | Fujitsu fi-6130 duplex scanner
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Is a brake roller the same as a pick roller?
Hi Tracy,
The brake roller is diffrent from the pick roller in all models. However, in Fujitsu fi-5120c, there is no brake roller, only Pad Assy and Pick roller are present.
Thanks,
TechSatya
Aug 24, 2011 | Fujitsu fi-5120C
Hi, I have a Scanner Fi-6130 and it said to replace pick roller,, of which I replaced both of them. it is still coming up "About time to replace Consumable". I keep ignoring it but am afraid...
Jun 22, 2011 | Fujitsu fi-6130 Flatbed Scanner
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Hope the above info is helpful.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
76 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
