Question about Retail Supplies
Royal Alpha 9155sc needs repair, Journal tape not printing
1 of 2 print heads (thermal) not printing
flexion1
  • 737 Answers
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
SOURCE: Thermal print head repair
I have an Evolis Pebble 4 Printer. We use this machine to Print at leat 2000 cards a day.
We would like to know from where OEM Printheads for this machine can be procured as the
cost of the originals is too hgh?
Posted on Nov 13, 2008
Gort007
  • 1187 Answers
SOURCE: could someone please tell me where can i buy
OfficeMax and Office Depot may have them.
Storemont (online) has the Royal Alpha 601 ($6.49): http://www.stormont.basics.com/product.asp?dp=2098041&f=
Posted on Sep 22, 2009
  • 3940 Answers
SOURCE: I have a cash management system Royal alpha
I find that a lot of serial to usb or parallel to usb converters do not work due to the fact you can't get bidirectional communication. In every case I have dealt with, the resolution was a dedicated port card to physically install a parallel or serial port in the system.
Posted on Jan 26, 2010
  • 610 Answers
SOURCE: Thermal Printer for Royal 600/601 sc Cash not printing
do you have tape in backwards? one side will print other side will not.
Posted on Feb 04, 2010
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Reciept side ink not printing
Need a new ink cartridge. Just like any printer they do not last forever before it needs changing and faded ink is classic sign that is the case. Skipped spots but good darkness would indicate some thing is dirty instead but that is not your situation.
Apr 15, 2015 | Sharp Royal Alpha 9155SC Cash Register
The printing on the register tape is too light to read.
There are two common reasons:
Firstly, the paper may be faulty. The cheaper the paper, the worse the reproduction. I see this all the time. The paper should feel reasonably thick and have a very shiny surface on one side (the print side). Secondly, the thermal head may be failing in the printer. The heads in the small cheap registers wear out quicker than the high end registers.
Apr 07, 2015 | Royal Alpha 710ML Cash Register
Royal alpha 9500ml
Head up. On your printer press down the green unit.
Aug 21, 2014 | Sharp Royal Alpha 9155SC Cash Register
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2ΒΌ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Receipt won't print on royal alpha 1000ml
Make sure you use thermal paper and no other kind.
May 12, 2012 | Royal 29043x Alpha 1000 Ml Cash Register
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Jun 28, 2009 | Royal Office Equipment & Supplies
Hope this helps.
Mark.
Aug 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
55 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
