Question about Epson Aculaser Mx14
Crum Id 093-926 Reset Black toner Catrige - Epson Aculaser Mx14
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
How do i toner low error remove
Dear Ateeq
the printer has unique CRUM ID chips attached to drum unit and toner unit. These are operate on RF power.
The toner empty can removed when you install a genuine toner cart. and its capacity is 20000 pages. but still you can print 10% of its capacity,i.e. 2000 pages from the time of first notice of toner low.
Thanks.
Feb 28, 2015 | Samsung SCX-6345N Printer
Error code 093-972
What model are you refering to ?
If this is a 74xx series model then it means that "Toner C CRUM Not In Position" That means that the black toner cartridge is not seating properly in position or the CRUM (counter chip) on the cartridge is missing or not in position. Easyest way to check is to replace black toner cartridge with a new one. The rest requires a service call.
Jul 31, 2014 | Xerox Phaser Office Equipment & Supplies
How to reset samsung ml4521fs printer
dear
there is a crum at right side of the toner car. there are 4 contact surface,cover with plastic(insulation) tape only the contact points. use. if not reseted you need to replace with a new crum chip of the toner cart.
Thanks and happy new year 2015
Jul 18, 2014 | Samsung Office Equipment & Supplies
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Epson Aculaser Mx14 Logo
684 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
