Question about Maytag Neptune Washing Machines
Why won't bleach despencer work ? - Neptune Maytag Washing Machines
When washing machine does not take fabric softener in still left in draw at end of wash
Hi,if you start the cycle again open draw despencer you should hear and see water wooshing inside if nothing then the valve that lets the water through must have packed up or despencer is blocked if you can hear the water clean despencer draw.
hope this was some help
Mar 28, 2015 | Washing Machines
Whirlpool washer model wfw9150ww01 won't dispense bleach
My guess is that the valve that pushes water into the bleach compartment has stopped working. It should be accessable from the top. I have some maytags similar to your machine that i have to remove the front panel to remove a couple screws to lift the top like a car hood. Not sure about your machine though.
Jan 12, 2013 | Washing Machines
I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. They simply won't dispense the bleach from the reservoir. Is there any underlying problem that may cause...
Maybe the water channel leading to the dispenser valve is not aligned......lid bowed? See Pic
""I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. ""
Describe fail......did you replace the valves or a repair service?
If you did the work what troubleshooting did you do on the valves? Did you check for 120VAC applied to the valve in Service Mode? Maybe the relay that applies 120VAC to the valve is not functioning or working intermittently........see pic of schematic of Control Board K3 is the Bleach Dispenser relay that applies 120VAC to that dispenser valve. Is it working 100% of the time? If not it may be a Control Board or connector issue ......but you need to troubleshoot.
Did you power up your old dispenser valves with a 120VAC cheater cord on the work bench to verify operation Open/Close?
I'm an owner not a appliance repair tech but have a electronics technical background.
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener does not despence
Hi
You'll need to clean the dispenser by removing it. Use white vinegar and spray then spray the dispenser & agitator with it too. Use hot water after a minute and vinegar will wash out the softener. Try using a soft brush to clean it. Try running a cycle with hot water and bleach (use no soap). Avoid using large amount of soap. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dispencer doesn't work for fabric softner or bleach
Remove the lid and check the dispensor solenoid
Feb 26, 2010 | GE WSXH208A Front Load Washer
Bleach and fabric softener won't despence
take out detergent tray (you need to push small lever to get the try out) their inside tray one more part it says bleach & softner take that part too then wash tray & that part too after use paper towel to dry tray now use your washer i think it will solve your problem...let me know it help or not..thanks.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Ice despencer won't make ice any more
Is it the despencer or the icemaker which thing showing the problem makes a difference to giving you info on the repair.
Jan 31, 2008 | Whirlpool GS6NBEXR Side by Side...
Washing Machines Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
