Question about Cambridge Audio Audio Players & Recorders
Looking for a replacement transformer for a Cambridge A5 Amplifier
Amplifier has sticker on side 230v 150va 30v-0-30v with 3 wires out of the top red orange and yellow the inputs are the normal brown and blue
  • Cambridge Audio Master
  • 3,382 Answers
A standard transformer would work just be sure the power rating is equal to or higher the voltage should stay about the same.
Posted on Nov 27, 2014
  • Alex Pupockin
    Alex Pupockin Jan 07, 2015
    Hi wer i can buy transformer for A5??
5 Suggested Answers
  • 231 Answers
SOURCE: Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Posted on Jul 21, 2009
Grubhead
  • 5484 Answers
SOURCE: The CS4000Watts amplifier I recently purchased,
Check the devices (for the faulty channel) located on the heatsink.
Posted on Jan 04, 2010
Grubhead
  • 5484 Answers
SOURCE: The main transformer in my Sherwood amplifier is
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Posted on Jan 25, 2010
  • 504 Answers
SOURCE: what transformer output volts supply used for cambridge audio C 70 preamp
+5 TO +9 VOOLT
Posted on May 28, 2012
Compressor want come on
Here is what to do . Pull out or turn off Electrical disconnect behind unit . Carefully remove panel covering controls in unit . Note most units have a flat panel with a few screws, but some GE units have a welded metal box on top of unit which needs to be removed. After exposing controls. replace or turn on disconnect. Then take a plastic handled screwdriver and push in on center of contactor (boxlike part with a lot of wires hooked ) If the compressor now comes on release contactor , and check for 24 Volts AC at base of contactor where thermostat (small wires that run on outside of black refrigerant line ) with thermostat on and calling for cool you should measure 24 to 28 volts . If voltage is present replace contactor after disconnecting from power. If no voltage go inside , remove cover from thermostat, and check for 24 volts between red ( R) and yellow (Y ) terminals on thermostat , If voltage is present , replace thermostat , no voltage check voltage in heater / air handler if you have voltage at air handler , replace thermostat wire from heater to thermostat / if no voltage check for blown fuse in heater , this should be either an inline fuse or an automotive type fuse plugged into circuit board (with power to heater disconnected check broken wire or black mark in fuse when held up to light. If fuse good turn on power to heater and check for 230v to one side of transformer, if you get voltage to Primary (incoming side ) of transformer, check output side of transformer for 24 - 28 volts. If transformer shows input but no output replace transformer after turning power off. If you heard a buzzing or grinding noise , when pushing in contactor , but compressor didn't start look at run capacitor (this is round or oval shaped object with wires going to contactor and compressor ) Looking at area where wires plug this should be a flat surface , if it looks domed shaped or bulging out , it is blown and needs replaced , use same mfd rating and 440 Volts to be on safe side. / If there was no noise from compressor when contactor was pushed in , put your hand on top of compressor (black object in center of unit ) If hot , allow to cool for at least three hours with power to unit turned off and retest . If compressor comes on after cooling , check for bad fan motor in outside unit (it may make a squealing or wining noise and stop runing for a while , also check for / clean outdoor coils
Hope this helps .
Thanks,
Alex
Oct 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
My Cambridge audio A5 amp has no power why?
The most common causes are in order a blown fuse, perhaps caused by a faulty output stage. Transformer faults. Other power supply faults. Have a look inside you might seen the part that has gone!
Aug 07, 2014 | Audio Players & Recorders
Cambridge A5 amplifier replacement transformer
Take the details to JAYCAR or some other electronic shop and see if it is possible to get a new one.
May 05, 2014 | Cars & Trucks
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Since gales last week and flickering house lights for over 24 hours my cambridge audio a740 won't switch on. Any connection? Not the plug fuse. Help.
Just take the top off! As long as it's unpluged from the mains you wont hurt yourself.
This is perhaps what you are looking for:
Apr 04, 2010 | Cambridge Audio Azur 640P Amplifier
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Jul 21, 2009 | Cambridge Audio Azur 640A Amplifier
78 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
