Question about Ricoh Aficio Office Equipment & Supplies
Our quark file has a silhouetted eps graphic
With the white background clipped using non-white areas. When printing this file to our Ricoh C830DN, the white area drops out using the PCL 6 1.1.0.0 driver but shows up with the PS3 1.2.0.0 one. We need to use the PS driver. What can we do to fix this?
Delphi51
  • 33 Answers
SOURCE: pcl 5e driver for hp laserjet 1320
Make sure you can view filenames with the trailing dot and 3 letters so you can see the type of file. (Use tools menu, folder options, view, uncheck "hide extensions for known types") Doubleclick on the downloaded file and note where it is unzipping to (c:\lj something or other). Open that folder. Right click on the file ending in .inf and choose "install" in the menu that pops up. If that fails, open the control panel, choose Printers & faxes, rightclick on the HP printer, and choose "properties". Look for the "update driver" button, probably under "advanced". Help it choose that .inf file.
Posted on Sep 10, 2007
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
  • 990 Answers
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
Posted on Feb 13, 2009
  • 29 Answers
SOURCE: i have a e-studio 352
you driver is not working order, you could download in the http://mba.toshiba.com/support/index.jsp, you only have to write or select the model and download it.
Good luck.
Posted on Mar 22, 2011
  • 16 Answers
SOURCE: Using the PCL drivers for our Ricoh Aficio MP 3350
Great solution. RPCS drivers I had found best drivers trouble free
Posted on May 04, 2013
Ricoh Aficio SP C830DN Transfer Unit SP C830DN calibration
The black transfer roller should be rise under the belt all time. Only the CMY rollers are rise at demand when printing in color. Check to see if the transfer roller under belt used for black transfer is rised and the belt is tensioned properly. Also check for a white knob at the back of the transfer unit and turn it manually until is vertically positioned. (check both positions).
May 15, 2018 | Ricoh Office Equipment & Supplies
FUNCTION PROBLEM SC681-19 FOR RICHO SP C830DN
This is an error code for the RFID which is the toner bottle chip on the the toner bottles. I would suggest you check the toner cartridges for any damaged or disconnected chips, have you changed to non ricoh toners as this can sometimes cause a problem. Check each bottle if you have any old empty bottles insert one of these into corresponding colour slot and you can then see which bottle is causing the error. Failing this the board will need to be changed. I have had errors on non ricoh bottles. you can also vac out the slot to clear spilt toner. hope this helps
Feb 24, 2014 | Ricoh Aficio 2035 Copier
Sc552-03 on my ricoh Aficio sp c830DN please what is the remedy
Jun 05, 2013 | Office Equipment & Supplies
Running Mac OS X (Snow Leopard)....Quark 7 will not launch due to damaged application preference....says to delete file and relaunch....that does not work... Also....when Quark was working on OS X (Snow...
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then deleted the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps.
Sep 13, 2011 | Computers & Internet
Help!...While 'collecting for output' an error -43(file not found). All images are OK. Not sure what to do...
Check under Usage and check that all the images are valid and updated. If these are correct, check whether the images are quark EPS files, if they are place the files in illustrator or photoshop (DO NOT OPEN THEM) and then save them in the appropriate format. Before you do this ensure that you have copies of these files .
Hope this helps.
Nov 03, 2009 | QuarkXPress
Color matching
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
May 20, 2009 | QuarkXPress
Missing WMF Graphic filter
I had the exact same problem and couldnt figure out what was going on...but I had a freak fix. I don't know how, but when I installed disc 4 (Picture It! 2000 Setup and Picture Disc) and disc 5 (Additional Art), I was able to access the program again. Hope this helps!
Apr 13, 2009 | Computers & Internet
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
