Question about NexxTech 175W Power Inverter
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the battery in the truck with or without the engine running. It won't work anywhere on the tractor. Input voltages are within half a volt or less between the 2 vehicles, and all between 11.6 and 14.2 volts. Output voltage from the inverter in the truck is 108 volts, which runs the laptop; 85 volts in the tractor, which will not. Why the difference? What's the solution?
    Problem Solver:
  • 10 Answers
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
Posted on Jul 24, 2014
2 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
have you charged it,and check if the battery is still ion good condition
Posted on Feb 26, 2010
Pavilion DV3 not working on a car charger That is working flawlessly on other hp nc6400 laptop they both work great on the 220v standard adapter! Why isnt my laptop charging?? Please help
the 220 v power of cities has 25 Amper
has your inverter 25 A . of course not
so this is right that tow power sources have 220 VOLTS but the important matter for working
a device by power source is the out put AMPER plus output Voltage.
good luck
gorbesia
Jun 29, 2011 | Inverter 175 Watt Power Car Adapter for...
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Jan 30, 2011 | NexxTech 175W Power Inverter
Can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974, and inverter is a roadpro 175watt/140watt constant with overload/overheat protection built in? the power...
you dont need to buy anything from radio shack, the inverter that you have will be just fine. i have used smaller and im sure cheaper inverters with no problem. i keep my company laptop constantly plugged in and charging all day everyday running service calls.
Dec 17, 2009 | Toshiba Satellite L305D-S5904 Laptop
Jul 25, 2009 | NexxTech 175W Power Inverter
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Fuse missing
    I would start with a 1.5 AMP fuse (175 watts / 12 VDC = 1.6 amp)
    Make sure the fuse is rated for at least 120 VAC. Hope this helps!..Gary
    Mar 10, 2009 | Dell 175 Watt Power Inverter Car Adapter...
    Power inverter pc 500 once u put power to it the red light comes on and beeps but no a/c power
    Hi there
    Not a great solution but makes sense.
    the ac adaptor for your alienware probably says input 240V ac 1.5Amps whilst the inverter can output 175W= 240V ac at 0.73Amps.
    I am surprised it actually worked, i had to buy a 300W inverter to run my laptop. would suggest you do the same.
    inverter is probably toast now anyway.
    Feb 25, 2009 | Alienware PC Systems 175 Watt Power...
    Ruining lap tops
    175 W inverter is not enough power for your computer and most of the cheap inverters do not put out a true sine wave. Buy one rated at least at 400w. Then it will output continuously at 300w. That should be sufficient for your computer. Your 175 w inverter is overtaxed then the voltage drops increasing amperage and burning things out.
    Jan 26, 2009 | NexxTech 175W Power Inverter
    Can't get power to my RoadPro 1500 DC to AC Power Inverter
    I have had this same problem with several power inverters over time. The problem is usually one of three things.
    Those starting with the simplest.
    1. Too much current being drawn on the inverter.
    Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
    2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
    Solution (Replace the fuses)
    3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
    If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
    Hope that helps.
    Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
    NexxTech 175W Power Inverter Logo
    123 people viewed this question
    Top NexxTech Electronics - Others Experts
    Are you a NexxTech Electronics - Other Expert? Answer questions, earn points and help others
