Question about 2000 Oldsmobile Alero Instrument Cluster Bulb
WHERE IS THE AIR PUMP LOCATED IN 2000 OLDS INTRIGUE
I'm working on a 2000 olds intrigue. Lighters stopped working.. The fuses don't say anything like lighter or aux. So I looked at them all and none are blown.. Is there an in line fuse?? If so were
John, Open passenger door wide, fuse box, passenger side end of dash, under removable trim cover.
The fuse marked Cigar Ltr./Aux.Pwr. 20 amp. is the fuse you want to look at. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.autofuseboxdiagram.com/10639-2000-oldsmobile-intrigue-fuse-box-diagram
2000 olds intrigue cigar lighter fuse Google Search
Where is the fuse for your cigarette lighter located at for your 98...
Where is the fuse for your cigarette lighter located at for your 99...
May 11, 2016 | Cars & Trucks
Replace heater core
Heater Core replacement 2000 Olds Intrigue - Car Forums and ...
www.automotiveforums.com > ... > Oldsmobile > Intrigue
Jan 1, 2014 - Trying to replace the heater core in my Intrigue. I've done heater cores before- perhaps a dozen. Mostly in the late 80's. Hate the job with a ...
Heater core shortcut - YouTube
? 4:40
https://www.youtube.com/watch?v=LsZoFoiJsdw
Apr 26, 2009 - Uploaded by realfixesrealfast
A short cut for removing a heater core on a Ford Taurus. ... 04 Jeep Grand Cherokee: how to remove dashboard and replace Heater Core / AC ...
Heater Core Replacement Olds Silhouette Chevy Venture ...
? 6:18
https://www.youtube.com/watch?v=rW23CtepYWU
Sep 8, 2014 - Uploaded by Buckwsr
I walk you through replacement of the front heater core on a 2000... I just finished replacing the fuel pump and sending unit on my2000 Olds ..
Oct 09, 2015 | 2000 Oldsmobile Intrigue
Where is the vacuum that controls the air vents on the dash of 2000 olds intrigue?
Its in the engine area....probly bad one way vacuum valve. A partstore like napa will help
Jun 29, 2015 | 2000 Oldsmobile Intrigue
Where is the water pump located on a 2001 olds. Intrigue?
If the engine is sideways, it would be located on the left side of the engine by the belts. See if a hose is hooked up to it.
Apr 02, 2015 | 2001 Oldsmobile Intrigue
BCM LOCATION 2000 OLDS INTRIGUE
It is located under the dash left side above the parking brake ! There are four wiring connectors to it !
Mar 17, 2014 | 2000 Oldsmobile Intrigue
Mpg for a 2000 olds intrigue
The 2000 Oldsmobile Intrigue gets 28 mpg city/hwy. If you dont think you are getting that, I suggest replacing the air cleaner, and running a few tanks of higher octane gas through.
Hope this helps.
Mike
Dec 29, 2011 | 2000 Oldsmobile Intrigue
2002 OLDS INTRIGUE....WATER LEAKING BACK OF ENGINE ....IMPOSSIBLE TO SEE FROM WHERE? WHERE IS THE WATER PUMP LOCATED?
if it has a 3.8l there is a good chance it is the intake gasket it is a VERY common problem with GM V-6 engines. the water pump is on the front of the motor
Sep 02, 2010 | 2000 Oldsmobile Intrigue
Where is oil filter located on 2000 olds intrigue
Not exactly sure on the intrigue, but on the Aurora 3.5 it is a cartridge filter accessed from a big black cap on the bottom of the oil pan. Use an oil filter wrench to get it off.
Jul 08, 2010 | 2000 Oldsmobile Intrigue
Can't fill up my 1999 Olds Intrigue with gas,
the filler pipe has collapsed ,its need renewing
Oct 17, 2009 | 2000 Oldsmobile Intrigue
A/c blowing hot on one side and cold on other
Bad servo ,you have to go under dash to replade.
Jul 30, 2009 | 2000 Oldsmobile Intrigue
2000 Oldsmobile Alero Instrument Cluster Bulb Logo
13 people viewed this question
Top GE Vehicle Parts & Accessories Experts
shadowpro
David Wiebe
Level 1 Expert
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
