Question about Epson Stylus Pro 9800 InkJet Printer
Service required 10004 epson 4880 - Epson Stylus Pro 9800 InkJet Printer
4 Suggested Answers
Inky
  • 691 Answers
SOURCE: epson 4000
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Posted on Aug 17, 2007
micromatikal
  • 2777 Answers
SOURCE: how do i reset the ssc service utility counter on
I don't quite understand the question here. I am very familiar with the SSC Service Utility, it's amazing really... but you use IT to reset counters on the Epson devices, there are no counters for the SSC Service Utility...
What are you trying to reset?
Posted on Oct 04, 2010
SOURCE: I have an epson 4880
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
Posted on Jun 20, 2011
Epson 4000
Aug 17, 2007 | Epson Stylus Pro 4000-PS InkJet Printer
MNT TK NEAR FULL what should I do replace mnt tk or cleaning the tank?
maintenance tank problem Epson 4880
I have my Epson pro 4880 down for four weeks. The Maintenance tank is rejected by printer. I bought brand new waste tank sensor and chips still says: "NO MNT TNK" it also would let do media setting through Epson LFP remote panel at all. I need help of what may be wrong. please???
Nov 16, 2012 | Epson 4880 Stylus Pro InkJet Printer
Service call error 10004
SERVICE CALL 00010014
Description
Failure of pressurizing
Jun 27, 2012 | Epson Stylus Pro 9800 InkJet Printer
Epson 4880 stylus pro service req. 10037
Hello Frank,
i have the same 10037 error code in my machine. On internet is says it is 00010037 Print Head thermistor error. I can not understand the problem and service employee could not solve.
I would really appreciate if you can tell me what was the reason of the problem in your machine how the problem is solved on your side?
Best Regards
Cagr
May 23, 2012 | Office Equipment & Supplies
Carriage Motor End of Life
reset Epson counter by use ssc service utility http://www.google.jo/url?sa=t&rct=j&q=reset%20epson%20soft&source=web&cd=1&sqi=2&ved=0CCYQ0gIoAjAA&url=http%3A%2F%2Fwww.ssclg.com%2Fepson.shtml&ei=NrSOT5rBCZK28QPWv82-Cw&usg=AFQjCNGMVcYQQRNmvWrGZlkzozOIshrfGQ
Apr 18, 2012 | Epson 4880 Stylus Pro InkJet Printer
The cyan cartridge is giving an alert "SET INK
Hello John! Welcome to FixYa!
Actually you need to replace the Ink Cartridge of your printer. When the Cyan in Cartridge indicate you to "Set the Ink Cartridge" then it means the cartridge is not supporting to your printer. Usually this problem can be solved by Resetting but as you told that you have tried this before and problem is still there so now you need to replace it as a whole.
If your printer is still in warranty then you can go for warranty claim but if it is now out of warranty then contact EPSON authorized service center and make sure to have duplicate original Ink Cartridge.
Moreover, i am providing you the Manual of your Printer, It can help you in all the problems regarding your printer. DOWNLOAD EPSON 4880 Stylus Printer Manual
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Jan 04, 2012 | Epson 4880 Stylus Pro InkJet Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Print head error 00010028
i have epson 4880. but now printer showing service Req. 00010028. pl tell me how to solve this problem
Jan 26, 2010 | Epson Stylus Pro 4800 InkJet Printer
Service req 10005
Check here -- there are two links depending on printer model they both reference an 10005 error code.
http://www.epson.com/cgi-bin/Store/WideFormat/WideFormatDetail.jsp?BV_UseBVCookie=yes&infoType=Support&oid=-12982&category=Wide+Format+Printers&menuSpec=4583
Dec 08, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
601 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
