Question about Kitchen Ranges
Kitchen aid double electric oven won't heat after a self clean cycle?
  • 833 Answers
SOURCE: kitchen aid slide in range - oven stopped working
Wynco, first thing I'd check is whether or not you are getting the 220 volts the unit needs. Find the circuit breaker and turn it off and then back on. This should be a dual or linked breaker. The breakers do corrode and wear out and may need to be replaced.
Posted on Dec 12, 2007
  • 2318 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
aborcass
  • 2651 Answers
SOURCE: kitchen aid single electric oven
soundsl ike youve blown a thermostat on the back wall of the unit(fairly common with the K/A appliance, unit wikk have ot be pulled out to check continuity on the thermosts( loactated behind back wall just between the broil element hook ups.
Posted on Apr 03, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
SOURCE: Kitchen Aid oven shut down during self
did a self clean and now the display wont work and oven dose not open
Posted on Aug 12, 2010
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Replaced oven light and now oven won't work
Does the light work? Will it heat if you remove the light?
Nov 24, 2012 | Amana ACS7270AS Electric Kitchen Range
Self cleaning Kitchen aid oven
Hi there
Could it that one if the small fuses have gone?
Take a lookkolbrun
Apr 18, 2012 | Kitchen Ranges
I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Feb 01, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
