Question about TecnoWind TWD90 Kitchen Hood
How do we order light bulbs for the hood - TecnoWind TWD90 Kitchen Hood
Replace marker light
Removal Procedure
  1. Open the hood.
  2. Remove the headlamp. Refer to Headlamp Bulb Replacement .
  3. Rotate the bulb and socket counterclockwise in order to remove the bulb and socket from the housing. Remove the side marker bulb (3) or turn signal/park bulb (4) from the socket.
Oct 01, 2015 | 2005 GMC Envoy
How do you remove front head light cover in order to replace headlight?
the head light bulb is on the back side
there is two locking pins under hood holding the assembly in
rotate 1/4 turn and pull up pull assembly put and unplug
remove retainer ring and remove bulb
assemble in reverse test new bulb before mounting light assembly back in
Jul 15, 2011 | 2003 Chevrolet TrailBlazer
How do you get the light bulb out of the hood?
there is a tool (suction cup) that dacor provides with unit or you can order the "kit" online for $30. i used some gloves with latex coating on palms to get "decent grip" to spin it out. that stainless stell rim actually pops out on my ventilation hood....it is similar to recessed lighting baffles...spring loaded....it may give you a bit more room to manuever your fingers.
Sep 30, 2009 | Dacor EHD3618SS Kitchen Hood
I need a replacement bulb Zephyr Pyramid range hood, I cnnaot find it anywhere.
According to the "Use, Care and Installation Guide for your unit,
Replacement bulbs are available at
specialty lighting stores. Purchase type
JDR E27 50W halogen bulbs.
Or to order bulbs, please call our service
center: 888-880-8368 or online parts store:
www.zephyronline.com
Jul 30, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Cannot find a replacement bulb (Phillips X4J-40 watt)
I had the same problem and found bulbs that fit through elightbulbs.com. You have to look for a European base, 40 Watt, 120 Volt incandescent light bulb. They are about $3.50 each plus shipping. I bought two and they are excellent. I've ordered another 6. They are shorter looking than the original Phillips bulbs, but just as bright and you don't have to replace the sockets. Good luck!
Apr 03, 2009 | TecnoWind 90 cm (approx. 36 in.) Classic...
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
Problems changing a light bulb :)
You need the suction bulb that came with the unit.  In case you do not have it, it is part #62408 and is about $2.00.  I am trying to figure out for myself how to get the lens cover off in order to access the bulb, and how to replace it when the new bulb is put in.
Mar 26, 2008 | Dacor Integrated Ventilation System - IVS1...
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
TecnoWind TWD90 Kitchen Hood Logo
112 people viewed this question
Top TecnoWind Kitchen Ranges Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Anthony Kelly
Anthony Kelly
Are you a TecnoWind Kitchen Range Expert? Answer questions, earn points and help others
