Question about Fisher and Paykel Dryers
How do i remove the front of ed56 dryer
Need to replace auto sensor on the door
Jimster
  • 240 Answers
SOURCE: GE Commerical Dryer
First, UNPLUG the unit from the wall please. Next, open the door, and on the inside top of the door area in the cabinet, you will see either 2 or 4 screws holding down the top of the dryer. Remove these screws, then lift the top off. Now, looking down inside the cabinet, you will see as screw on either side, towards the top that holds the front onto the cabinet. Remove these two screws, then fold the front down towards you, and lift slightly to remove the front from the slats at the bottom. Use caution, because more than likely you will still have wires attached going to the thermostats, door switch, etc. Also be sure when replacing the felt, you use a lot of caution around metal edges. These things are razor sharp, and will put a deep cut on you in less than a second. Let me know if you need further help or information. Thanks and Good Luck!!!!
Posted on Feb 15, 2008
SOURCE: ED56 Dryer continually stops after 1 minute
Is there a chance your vent is clogged? GL
Posted on May 04, 2009
  • 351 Answers
SOURCE: Need replacement part for front dryer door sensor - broken
i sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
Posted on Jun 26, 2009
SOURCE: Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Posted on Apr 19, 2010
vijaivee
  • 120 Answers
SOURCE: Model ED56 Dryer. Sensor can't
your sensor has some problem. change the sensor
Posted on Jun 12, 2011
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Mar 06, 2010 | Fisher and Paykel Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel ED56 auto sensor dryer - just not working!
It might be the circuit breaker of the mains/AC line. Pls try using another outlet/source of power. Alternately, most dryers have their own circuit breaker at the back of the unit. This would appear to be a push button switch, pls try see if your unit has one and press on it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
How to replace the bearing on the drum of a fisher&paykel dryer ED56
top load dryer?? open top right end of drum remove toex screw and cover brass bearing slides out.. front load pry up top srews top inside front lift front out remove belt lift drum out bearing in back on rear wall
Apr 24, 2008 | Dryers
Open Questions:
Dryers Logo
14 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
