Question about Flojet Plumbing
Par-max 3 model30620 - Flojet Plumbing
I have 1994 chevy 1500 it failed smog at idle . the hc ppm was100 max and i was putting out 848 what should i do
Diagnose a running rich condition. Too much gas, or too little air. Start with a clean air filter. Have your fuel injectors checked for leaking, stuck open, being out of whack. Make sure PCV system is working, along with the EGR. Is ignition system in good shape, good plugs, plug wires, and coil? If ignition is not up to par, you could have unburned gas getting through engine. Remember, it is running too rich. Good luck.
Apr 08, 2016 | Cars & Trucks
New biss key of ptv k feed
new biss key for ptv k feed
d7c86400e2b51900.100% working.
Mar 11, 2011 | Televison & Video
How to reset maintenance required light for 1991 mitsubishi mighty max
there is a small switch behind one of the switch blank off plates to the right of the steering column. It is a very small switch about 6" deep into the dash, hard to find easy to reset.
Nov 12, 2010 | 1990 Mitsubishi Mighty Max
I ride the cycle for about a half hour and it cuts off. The battery will die. Replaced the stater and the battery. Fuses are good and checked the output charging and that is up to par also. All connections...
Make sure the battery is good, ie. no bad cells........should read 13.2 volts min. Take it to any local parts store and have them load test the battery. If battery tests good, make sure that the charging system is not putting out more that 14.8 volts max. If it is putting out more than max, replace voltage regulator/rectifier.
Nov 02, 2010 | 2005 Suzuki Boulevard S83
Scaner Short Cut
did u tried to search for the scanner button software ? try to see for it
Jul 23, 2010 | Canon LIDE20 Flatbed Scanner
Plumbing Logo
23 people viewed this question
Top Flojet Plumbing Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a Flojet Plumbing Expert? Answer questions, earn points and help others
