Question about Canon iRC3100 Printer
ERROR E 0006 - Canon iRC3100 Printer
Error E000002-0006
Replace the main Thermistor or Fuser Unit.
May 05, 2014 | Canon imageRUNNER C3200 Color Printer
E000002 0006
I'm going to guess.... You have a Canon copier???? The error means that there is problem with the fixing unit. It may be rest, but I don't know the make or model of your copier. Good Luck
May 07, 2013 | Office Equipment & Supplies
Error E000002-0006 message
its fuser unit temp. rise detection
to reset the error:
Enter the service mode:
press asterix key ( add. functions ) "*"
press 2
press 8
With right arrow, go to CLEAR, press OK, with arrow choose Engine and OK.
Turn off and on.
Apr 02, 2013 | Canon ImageRunner 2020i Copier
Enter test mode
Hi
Problem with the temperature sensor.
Try disconnecting/unplugging from power and connecting after a while.
Feb 29, 2012 | Office Equipment & Supplies
Generic error code 0006:0010 on panda internet security 2012 Help?
Reason- The main cause of this error is the wrong info. entered during the registration and activation of Panda AntiVirus products. The Panda users, during the product activation process, enter wrong information in the space provided.
Sep 18, 2011 | Panda Antivirus Pro 2011 Bilingual OEM W/...
Konica 7145 i have an error message 0006 I have replaced drum in drum assy. it gave me an f26-3 error message performed L detection now it gives 0006?
Check Toner control sensor board, on drum unit behind drum, is clean, try L-detect then, try it a couple of times. If that fails you will then have to change developer, and perform L-detect.
Sep 13, 2010 | Office Equipment & Supplies
Error code 0006:0904 trying to activate a second pc
Perhaps this is because you have only purchased a single licence? Ask Panda why you can't activate again, and what their error code means.
Jan 16, 2010 | Panda Global Protection 2009 - 3 User for...
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
Canon iRC3100 Printer Logo
old marine
old marine
