Question about Lexmark MS310dn Monochrome Laser Printer 35S0100
How to reset a ms310dn printer back to factory defaults
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Printer does not reset
NVRAM initialization/cold reset
NVRAM initializer sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initializer resets the following:
! all menu settings to factory default values
! factory settings such as formatter number, page counts, factory
paper settings
To perform NVRAM initialization
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
4 Release the GO button.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Or download the service manual here ..
http://www.google.com.sa/search?site=webhp&source=hp&q=hp+laserjet+1200+printer+service+manual&oq=+HP+LaserJet+1200+Printer+service+&gs_l=hp.1.0.0j0i22i30l6.200423.206442.0.207913.10.10.0.0.0.0.763.3187.0j3j2j3j1j0j1.10.0...0.0...1c.1j2.9.hp.QNDAx6nGCA0
Apr 18, 2013 | HP LaserJet 1200 Printer
My brother laser will not reset back to factory defaults
If you are using the printer in a LAN or Wireless LAN, you must assign to it an IP address compatible with your network. You do that by opening the Web admin interface of your router and assigning to the printer an address that is still free. Try 192.168.1.178 but that depends on the default gateway (192.168.1.1) that you defined for your router.
Aug 02, 2012 | Brother Office Equipment & Supplies
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
How do I do a reset
This printer doesn't support a COLD RESET
However it will set customer accessible menu settings back to factory default settings
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1. Use the (Left arrow) or the (Right arrow) button to select Service, and then press
(Select).
2. Use the (Left arrow) or the (Right arrow) button to select Restore defaults, and then
press (Select).
The device automatically restarts.
Feb 09, 2011 | HP LaserJet 2605dn Printer
When I go to scan a document it asks me for a password and I don't have one for it. How do I get it back to factory settings? it's a lexmark x4850
This is how you get the printer back to its default settings. On the Main Menu, scroll down to Maintenance > scroll down to Reset Defaults. First option is to reset to factory defaults. Then, it will give you second option if you want to reset the Network Settings as well. Hope this helps.
Apr 07, 2010 | Lexmark X4270 All-In-One InkJet Printer
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
May 13, 2008 | TallyGenicom 8008 Laser Printer
Lexmark MS310dn Monochrome Laser Printer 35S0100 Logo
293 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
