Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
My mower runs and blade spins but won't go forward or reverse
wadembly
  • 475 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
  • 7 Answers
SOURCE: Engine rpm is not steady.
sounds like the spring on the carburator butterfly valve is weak ... when at idel it surges the engine but when the blade is enguaged the engine evens out
Posted on Jun 17, 2009
  • 95 Answers
SOURCE: craftsman model 917.271814 will not go forward or
Check the drive belt that runs back to the transaxle,it sounds like it broke.If the belt is in the pulley check to see if the transaxle pulley is turning when the clutch is out.Also make sure both wheel axle keys are in the rear wheels.If all this checks out the transaxle may have broke,look underneath to see if it is broken there.
Posted on Aug 06, 2009
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Cub cadet hydrostatic
brake lever on trans could be stuck on lay down and push lever to free up
Jun 04, 2013 | Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Model RZT42. When you back up the blades shut and when I go back to forward, the blades will not engage.
Some of the newer riding mowers have a safety system on them that won't let the blades work while you are backing up. If the blades are engaged and you put it in reverse they will stop. You usually have to reset the blades, turn them off then back on, when you put it back in forward.
Jul 06, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
73 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
