Question about Panasonic KX-T7633 Corded Phone
ICD Group FWD to external number
Panasonic TDA 600. I cant seem to find the feature code for Group FWD to CO. I have tried the *714XXXX. I have done it on other systems a while back. No longer have access to those now. I want to forward the ICD to an outside number immediately.Incoming call from a PRI.
    Problem Solver:
  • 19 Answers
Its *714 1 ICD# Phone Number "#"
Posted on Jun 23, 2009
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Jun 19, 2011 | Lands Phones
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
I have 3 CO lines coming in. I want the 3rd to be available, but not to ring (it is the fax line). How can i have the first two ring, but not the 3rd?
TDA ringing is controlled by ICD groups. If the fax is part of the system (an extension) then you need to set up an ICD group (like #2) that puts the fax extension in it and rings only the fax. If your fax is external to the phone system but you still want to use the fax line, then you take the incoming CO out of any ring group at all (leave the column blank). All of this requires installer access or a really good read on the PTPM manual.
Carl
Mar 30, 2011 | Panasonic KX-TDA50 Phone
We've added 2 extensions in the office, but we can't pick up external calls on them - how do we add them to the group call facility on the T7633
The extensions need to be added to the ICD group and given either an Immediate or some ring delay. It's fairly easy to tell because if they're not in the group the line is red and doesn't blink on incoming calls. By default ICD group 1 is access code 600 or 601(try dialing it on the intercom from any phone and see if your phones don't start ringing). Unfortunately, you need higher level access to modify ICD groups. It's either done from the programming tool, or a phone with a class of service allowed to make such changes.
Carl
Mar 23, 2011 | Panasonic KX-T7633 Corded Phone
We have a KX-T7630 Panasonic phone system and we need to attach a caller id that diplays at least 20 calls; are they all compatible or do I need to buy a specific one?
It doesn't work that way. First of all, you install a caller-id card in your system, then the installer programs a call log button on a phone. This can log all calls into an ICD group and you get a maximum of 100 records per ICD group and a minimum of 480 records per system in a TDA-50. Those numbers change for ICD groups and increase on a TDA/TDE 100 or larger system.
Unless you understand and have access to system programming, it's a dealer program function.
Carl
Nov 13, 2010 | Panasonic KX-T7630 Corded Phone
KX-T7630 - forward to voice mail
Assuming this is a Panasonic system TDA50, TDA or TDE 100/200 or NCP systems. There are many fwd codes on these systems,done on a per phone basis. To do a fwd all calls (meaning the phone will not ring) dial code *7102+9+number+pound. If you would like to set for call fwd no answer then *7104+9+number+pound. And for call fwd busy no anser the code is *7105+9+number+pound. Keep in mind this is on a per phone basis. If your company is using a ring group to ring the phones this will need to be setup different using the day/night mode and set the night to go to a group that is fwd to your answer service. A phone must be assigned to the group then that phone can set group fwd by dialing *7141+group number+9+phone number+pound. Example if I was using group 3, defualt number 603, to number 555-1234 and group 603 has ext. 102 assign to it then from ext. 102 dial *714160395551234#.
Hope this helps!
Jul 27, 2009 | Panasonic KX-T7630 Corded Phone
Call forwarding
The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
Carl
May 11, 2009 | Panasonic KX-T7630 Corded Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
Sep 22, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T633?
If it were my choice, I'd set up an ICD number and forward that to an outside number. Something like pick 400 or 600 plus your extension like 605 (they tend to be defined by default), and go into the group fwd command to dial your cell numbers.
Any call placed from anywhere, either VM, internal, or transfer will go out on another line and dial your cell...assuming you put the fwd number in both places.
Carl
Aug 20, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
614 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
