Question about Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure Washer 020488
Troy bilt 2800 shop maunal
Look for spring and linkage picture
The spring at the underside rear of the Troy Bilt riding mower that I have is broken and the mower won't go in gear.
May need to shop it. It moves and has a blade...u can buy serviceguides...read safety first
Oct 07, 2015 | Troy Garden
Troy bilt troubleshooting
start from the most obvious and work your way down. worn misalinged belt , inproper tension, broken tensioner spring or some thing binding in engagment linkage, forien debris causing limited travel, worn gears in housing ? any klunking or grinding noise from housing?
Aug 13, 2014 | Troy-Bilt Garden
Troy bilt
It thinks that the PTO is on. Do you have two different key positions? If so try both for a temp fix. If not it's probably a linkage or switch problem.
Aug 02, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
020488 USER MANUAL
Contact Troy-Bilt...
http://troybilt.custhelp.com/
They have a page for Pressure Washers explaining thet tehy do not build their own pressure washers...
http://troybilt.custhelp.com/app/answers/detail/a_id/430
Jul 14, 2014 | Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure...
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How to adjust the governor
if you didnt change anything on gov dont start now.
you may have linkage in wrong hole
or bent linkage , or missing spring
Jan 18, 2014 | Troy-Bilt 420cc 45-in Two-Stage Gas Snow...
Troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Apr 18, 2010 | Troy Garden
Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure Washer 020488 Logo
44 people viewed this question
Top Troy-Bilt XP Garden Experts
CrisO
Ron Durham
Bill Boyd
Are you a Troy-Bilt XP Garden Expert? Answer questions, earn points and help others
