Question about Envision G22LWK 22" LCD Monitor
Power button pushed displays power button locked
Have tried a variety of solutions on the web nothing turns the power button locked message off
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
I can't turn my tv off. When I try, "power locked"
try pressing both volume buttons and the menu button at the same time.
Feb 28, 2011 | AOC L22h998 22 in. TV
I'm getting an error messege on a hp photosmart C7180 all in one 0xc18a0106. please help me. I've tried un and reinstalling the software. New ink cartriges. Nothing works.
Solution 1:
  • Push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
  • One more time: push "OK", "Cancel", "Black" and "Color" all at once while turning the printer off.
  • Turn it back on.
Solution 2: Resetting the product:
  • Without turning off the product, disconnect the USB cable from the rear of the product.
  • Remove the cartridges from the product.
  • Wait for the "Insert Cartridges" message on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
Solution 3:
  • 1. Get the unit into the "Support Menu" by following these steps: Press and hold the "*" key. Press the "#" key and release both keys. Display should say "Enter Special Key Combo". Press and release in sequence the "1", "2" and "3" buttons. Display should say "Support"
  • 2. Press and release the right arrow button until the display says "System Configuration Menu".
  • 3. Press and release the "OK" button.
  • 4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • 5. Press and release the "OK" button.
  • 6. Display should say "Hardware failure status: Clear. Press OK to clear".
  • 7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • 8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • 11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • 12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
  • 13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
  • 14. If the error is still there, or reoccurs replace the unit.
Feb 24, 2011 | Office Equipment & Supplies
Blanco BFW712-BFW716 No Matter what setting is made
The e in the 'C on e' message is nothing. the 'C on' means that the child lock is on. To turn the child lock off simply press the 'Quick Wash'and 'Anti-creasing' function buttons at the same time for 3 seconds. The display will show 'C off' you can then change your programs or cancel the wash altogether by pushing the start/pause button for 3 secs. Hope this helped!
Nov 02, 2009 | Washing Machines
Buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Sep 20, 2009 | AOC L24H898 24 in. LCD TV
W2361VG Monitor "OSD Locked" and service menu
This just means the On Screen Display (OSD) is locked. Press and hold the menu button on the front panel for 10 seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
ASUS Z91H PUSHED POWER BUTTON BUT WITHOUT DISPLAY
Try pressing the power button and press [del] button. See if it goes to the bios setup page. If it does, have your harddisk checked. It could be corrupt OS or problem with your harddisk.
Sep 12, 2008 | Computers & Internet
Lock message
Hi!
My DMR-ES10 appears since last month, the same message, and lets myself crazy!
Today, after a desperate try, pressing the buttons, I found the solution:
Simple press the POWER BUTTON and STOP BUTTON of the unit for a few seconds...
VOILá: The UNLOCK message appears in the display and the unit return to operate without the lock message !!!
For Lock again, press the same buttons at same way until appears the Lock message in the display.
This is an undocumented command...
I hope to help you!
Mar 25, 2008 | Panasonic DMR-ES10 DVD Recorder
Lexmark X83 "Unlock Scanner" error
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Oct 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Envision G22LWK 22" LCD Monitor Logo
41 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
