Question about Sony LBT-ZX66i Shelf System
Mine shuts off after a few seconds.
I took the main case off to look inside and a found what looks like dried liquid under the main power component, Any idea on what happened to my radio?
2 Suggested Answers
  • 188 Answers
SOURCE: Does the above have a fuse inside the case / AC
yes you will find 2 or 3 fuses inside the power supply, see and smell for some burnt parts, like trancistors it will be 3 or 5 legged device with a metal back.
if some thing is burnt do not replace fuse the power supply needs to replaced.
beware replace fuse only if no parts are burnt, do not test in open state to avoid electrical shock.
Posted on Dec 23, 2010
Hi... i have a Toshiba satellite pro model pc laptop. Unfortunatly by accedent my PC wetted as my kid urinated. my system is not power up till now.. i tried many times but it is dead.. not at all power...
When this happens, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Mar 27, 2011 | Toshiba Satellite L500 Series Notebook
Spilled water on my keyboard, touch pad stopped working. Dried it ff and left it for an hour. Unfortunately curser/ Touch pad still not working and can no longer connect to the iternet, seems like the...
Feb 26, 2011 | ASUS Computers & Internet
It got wet and now wont turn on. It was diet soda that sprung a leak in my pocketbook. I grabbed cell phone first and camera second but while not immersed it probably did get inside. I do get a quick turn...
hmmm... stop turning it on yet.. let it dry for maybe 24~48 hours then try to turn it on. If problem persists, contact your home support from this LINK.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 02, 2011 | Canon PowerShot SD1400 IS IXUS 130...
Some liquid sinked neary Power Button of my MacBook Pro sealed; and it does not turn it on normally. Some time it turn on if I keeps pushed power button for about 60-100 seconds at once. Plz advice...
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
When you are done, re-assemble back the laptop.
Feb 01, 2011 | Computers & Internet
How To Fix A Laptop Sony Vaio With Water Damage & not turn up
Jan 02, 2011 | Computers & Internet
My laptop was damaged with water and when i try to switch it on . it hows the lights and it fans start and stop suddenly. the finally it doesnt power on.
Dec 27, 2010 | Compaq Hewlett Packard Presario F756NR...
Dumped hot tea on key board and it shut down
Nov 22, 2010 | Panasonic Toughbook CF-51 Notebook
I spilled hot tea on the key board and it turnned off
A glass of wine was spilled on my laptop. It would still power up but the screen was black. Now it won't even power up. Is it worth getting repaired, or should I get a new one?
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
If it still does not work, the motherboard might be damaged & needs to be replaced.
Oct 21, 2010 | HP G60-235DX Notebook
Liquid spash on Samsung LCD monitor - now won't power up.
It can ruin your computer. Act quickly if this happens, because it only takes seconds for liquids to destroy the hard drive of a laptop computer.
Step One
Shut down the computer immediately.
Step Two
Wipe up any liquid. Tilt the computer to the side to drain any liquids.
Step Three
Remove any removable parts from the laptop, including the power cord, printer and mouse cables, the floppy drive, CD drive, modem cards and battery. Do not disassemble the laptop body to remove internal parts.
Step Four
Once the parts are removed, gently lift the computer and turn it to the side and upside down to drain any liquid. Tilt the computer in a variety of directions to verify that there are no pools of liquid lurking, but be careful not to shake it or handle it roughly.
Step Five
Repeat with the floppy drive and other removable parts.
Step Six
Use a hair dryer on a cool setting to dry the laptop and its parts if you can.
Step Seven
Allow the computer and its removable parts to dry for 24 hours before you reassemble it and turn it back on. (If you are under a tight deadline, let the laptop dry for at least an hour before you reassemble it.)
Step Eight
If the computer does not work properly or does not turn on, bring it to a computer repair professional, although the damage might be irreparable. Spills are one of the leading causes of laptop deaths.
Jan 21, 2008 | Panasonic Toughbook 17 PC Notebook
Sony LBT-ZX66i Shelf System Logo
53 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
