Question about Maytag SkyBox MBV1976A Beverage Dispenser
The vending on my maytag skybox stopped working
Any idea what parts I need to replace if my machine still cools but the vending machine is not working?
  • 221 Answers
What do the led's do when you try to dispense a product?
Posted on Jul 23, 2014
5 Suggested Answers
  • 7 Answers
SOURCE: maytag skybox stopped cooling
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Posted on Jul 04, 2008
SOURCE: Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Posted on Jun 05, 2009
SOURCE: Maytag Skybox MBV1976AAB Compressor Start Relay
I just ran into this problem on a friends Skybox. It would not cool, took apart and checked start capacitor... checked okay. I was about ready to diagnose the problem as the compressor itself, then I took apart the little white connector that plugs directly into the compressor itself. Inside this white, 3 prong connector there is a little round resistor plate. It was cracked up and fried. Both sides were craked and allowing the electricity to pass directly through the resistor, cause the start cap not to work at all and causing the thermal overload to trip out after a few seconds of a no-start. I temp fixed this by turning the round resistor, which now looked like a rectangle, to fit between both sides of contacts. Hoped this helped!
Posted on Aug 27, 2009
SOURCE: Replacement for Skybox compressor
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Posted on Jan 29, 2010
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox not cooling need name of place and parts number for serial 10170778EJ. Model MVB1976AAB
before replacing parts. unplug it and from back and under neath get all the dust out,best to blow air in there to remove dust than plug it back in and leave it on number 3 setting for 6 to 8 hours than if cold you can adjust the settings.
or part location is at www.maytage.com/skybox parts
Good Luck Im pretty sure you won't need to buy part's after air cleaning
Apr 08, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
Go to www.apdepot.com and enter your model number under Brand :Maytag you will see a parts breakdown and you can buy it online
Oct 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox parts
you need the numbers off the compresser to get the BTU of it before that question can be answered. But your right this is a non replacement part (you cant buy it) it may cross but need cooling capacity first
Jul 28, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
176 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
