Question about Bosch Classixx WFC 2465 Front Load Washer
Our mastermind 708 westinghouse front loiader is coming up with d3 or de on its screen what is wrong and how do i fix it please help thankyou
    Novelist:
  • 133 Answers
Dear Ashleydav327
This error normally occurs when there is error with intake/expel of water.
  1. Check that the intake hoses are not clogged and the small filter underneath is clean (you can use an old tooth-brush to clean it)
  2. Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver). Check for any stuff stuck there... Note: drain with the small pipe into a bucket so when you open it you don't have water everywhere.
Please let me know if that works.
Regards,
Srinivas
Posted on Jun 22, 2009
  • Srinivas Dhulipala
    Srinivas Dhulipala Jun 24, 2009
    Does the above given solution work? Any updates? Waiting for your response..
    Thanks and Regards,
    Srinivas.
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Jan 07, 2011 | Westinghouse Washing Machines
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Apr 13, 2009 | Washing Machines
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Jun 03, 2008 | Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
169 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
