Question about Coffee Makers & Espresso Machines
Reset lattissima How to reset latissma plus to original factory settings
old marine
  • 1973 Answers
SOURCE: looking to reset to original factory settings
On the camera's menu system, under Setup2, look for the option titled "Clear Settings". When selected, you can either clear just the Custom Settings, or you can clear all camera settings, which restores it to the factory defaults.
Posted on Jan 05, 2009
  • 3940 Answers
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
Posted on Apr 16, 2009
SOURCE: how do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Posted on Sep 23, 2009
SOURCE: How do i reset my lenovo t410 to factory settings?
Read the manual and it will tell you the process.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Factory Restore or System Recovery.
Why not consider another option?
System Restore will allow you to select a Restore Point (date and time) to set your system back to when it was working ok. It does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Date you selected).
System Recovery (sometimes referred to as Factory Restore) will set your system back to when you first purchased it. It Deletes Everything. Most times the System Recovery does not work unless there is a recovery partition on your hard drive created by the manufacturer. If you are trying to recover from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall Windows. Look on your computer for the Certificate of Authentication (COA) Sticker. It will tell you what operating system is on your computer and it will give you the Product Key Code (a series of 5 letters and numbers) that you will need to activate windows. If you don't have an operating system disk, borrow one from a neighbor, friend, relative or co-worker. Just make sure it is the same as your COA Sticker's operating system or it will never activate. Also make sure you get the COA Product Key Code for the disk you borrow because sometimes the system will ask for the one that is on your system and sometimes it will ask for the one from the installation disk.
Posted on Jun 07, 2012
SOURCE: reset supertooth HD to original factory settings
To reset you SuperTooth HD:
Turn off the device. Press and hold all three buttons until the left LED indicator starts blinking Blue and Red this means that your SuperTooth HD device has been reset. You will soon be prompted for language information like the first time you used your SuperTooth HD device.
Note: Disconnect all handheld devices from your SuperTooth HD device before performing a Reset.
Posted on Oct 19, 2012
My nespresso Larissa only drips a small amount when I press the large cup button?
After starting the machine press all 4 lit buttons on the top of the machine simultaneously for a few seconds. That will reset the volumes to factory settings. Decalcify your machine according to the manual provided with the decalcifying kit and the special nozzle for the milk steamer.
If if that does not work fill the water tank and the (clean) milk frother container with the 50/50 decalcifying solution + water and install as usual for making cappuccino (without a coffee capsule). Turn on machine and when the buttons light up press the large cappuccino button. Instead of cappucino you will get hopefully any of the residue from the entire system flushed out. Repeat until you used up the decalcifying solution in both containers. Discard and rinse a couple of times with clear water in both containers. Good luck - worked for my machine.
Oct 11, 2014 | DeLonghi Coffee Makers & Espresso Machines
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
My Kenmore H2 Plus needs to be reset to factory settings. Cannot find how to in the manual.
Not sure if this will work with this model but try this:
1-Turn off and unplug the machine. Plug the washer back in and wait for the control panel to light up. This resets the washer back to the original factory settings.
2-Unlock the control panel by simultaneously pushing and holding down the Options and Select button for 10 seconds if you see a lock icon on the control display.
3-Push whichever new options you need, and wait for the control panel to flash and reset the washer's options.
Apr 22, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
I want to reset the ringtone to the original for my Samsung Galaxy Ace Plus
go to audio profile choose ringtone what you want...
or go to settings ang privacy and factory data reset click
{remember dont check arase sd card......b-cause you're data will be damage.
Feb 18, 2013 | Samsung Galaxy Ace Plus S7500 - Black...
Forget my password
In case you have lost the password, all you can do is to reset the router to its original/ factory settings. This can be done by pressing the reset button at the back side of the router for few second. THIS WILL RESET ALL ROUTER SETTINGS. NOTE THAT YOU HAVE TO MAKE ALL THE CONFIGURATIONS AGAIN
Don't forget to rate the solution. Thumbs Up!
Nov 23, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
How do i reset my yamaha dx 100 back to original factory settings
Aug 28, 2009 | Yamaha Computers & Internet
Reset to factory original
If you go into the "set-up" menu you should find an option which allows you to reset all the settings back to factory original.
Sep 28, 2007 | Fuji FinePix V10 Digital Camera
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
