Question about Intel Entry Storage System SS4200E NAS Serial ATA300 RAID 0 1 5 10 Gigabit Ethernet Network Storage Server
How do i factory reset a nobi convertible - Intel Entry Storage System SS4200E NAS Serial ATA300 RAID 0 1 5 10 Gigabit Ethernet Network Storage Server
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    My nobis tablet is stuck on the nobis start up screen. How do I fix it.
    If you Google NobisNB09 stuck on GO you will find many angry people who have the same problem. Rarely does the factory reset procedure work to fix it. IMO they have a problem with faulty internal SD chips. So, what I'm saying is you may not be able to fix the problem other than trying to get an RMA and sending it back for repair if it's still in the warranty period.
    Here is the factory reset procedure.
    1) press and hold at the same time both the power button and the volume(-) button.
    2) keep holding them until you see the Nobis screen, Then it will go off. Keep on holding both buttons down for perhaps ten or fifteen more seconds and finally you will see a screen with some green text options
    3) Among the options is one that says something like "wipe data/factory reset.
    4) Using the volume (+) button scroll to it and then press the power button once to select it.
    5) Another screen will come up with text options of no, no no for five or six lines with one that has a go ahead for the reset option. Again, using the volume (+) to scroll to the reset option and select it using one push of the power button.
    6) you will get a reboot option.
    7) reboot by pushing the power button, it will turn off.
    8) Give it a minute or so and then push the start button and
    hold it until you see the Nobis screen. Let it go and wait. If the hardware's OK it will go through the initialization routine which
    should take several minutes. Anything more than about ten
    minutes without going to the set up screen indicates you have
    bad hardware such as a faulty internal SD memory.
    One hint: turn off your wi-fi router so it can't connect to wi-fi.
    It will boot up with the wi-fi ON and it will connect to any open
    router it can find and commence to download updates for all the apps. This makes it take forever and can completely fill
    up the available app partition memory and result in another failure to boot up next time.
    IMO the Nobis NBOP is a POS! I have one so I know.
    Apr 06, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    How to get a nobis NB07 it worked fine then it froze during boot up at go so I shut it down by holding the power then after it shut of I pressed factory reset now it won't turn on at all even let it c
    Question: Were you trying to jail break it? I found a forum that may have useful information to reload the firmware.
    Otherwise, there are often external buttons on the sides of the device that may allow you to get it to reset and recover.
    Best of luck... Nobis NB07 and DA 741QHD rooting and ROM thread
    Feb 03, 2015 | Cell Phones
    Nobis tablet froze and won't go past nobis screen
    Do a factory restore, using the buttons on the tablet. The procedure varies but typically it's Hold VOLUME DOWN and POWER buttons at the same time. When (if) you get a menu, choose factory reset. The sad news is she will lose all her pics, music, apps, etc. but the tablet should work.
    Jul 20, 2014 | Tablets & eReaders
    How to fix Nobis 9" tablet? Stuck on go screen.
    You need to do a factory reset .
    Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
    That should reset to factory original condition.
    Jun 01, 2014 | Computers & Internet
    Nobis NB09 has error launching
    i get this when i boot it up unfortunately the process com.google.process.gapps has stopped ok what does this mean
    Jan 29, 2014 | Tablets & eReaders
    Intel Entry Storage System SS4200E NAS Serial ATA300 RAID 0 1 5 10 Gigabit Ethernet Network Storage Server Logo
    80 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
