Question about GE Advantium SCA2001BSS Microwave Oven
Microwave when trying to microwave sparks and smoke starts. I notesed the cover on right side when looking in microwave has hole burned through it what do I need to do.
  • bill petro Nov 14, 2007
    I have an SCA 2000 (Oct. 1999) model. We do have sparks when we use the advantium only. When we use the microwave settings there is no problem. we do not use metal pans in the oven. any advice?
  • Anonymous Nov 30, 2007
    mine also sparks a lot the sparks are at the nvlon piece taht turns the plate. So bad that I can't use it. it turned out to be a expensive piece of junk. The handle also pulled off.
  • 225 Answers
Check inside the microwave oven , at high voltage section wiring probem, change the wiring, and magnetron, other related spares.
Posted on Nov 04, 2007
Kenmore microwave 80082 sparking from an inside panel
If your positive it is not arcing behind the waveguide cover I would think it has to be in the control area. You will have to turn off power to the unit and remove the control panel and look to see if you can find any burn marks or soot, to indicate where your problem may be. I have found burnt connectors at the relays or even possibly burnt wires to the door switches. Careful! the capacitor on these can hold a charge for a long time and can shock you pretty good. Only work on something like this with the power to it off and the capacitor discharged. Microwaves do not come through the little round holes those are typically an RF screen to prevent microwaves from getting through. A lot of times that is where the cavity lamp shines through.
Aug 14, 2017 | Microwave Ovens
SParks and smoke from microwave
it may be repairable but not by yourself
take it in for a quote and proper diagnosis
Aug 31, 2017 | Panasonic Microwave Ovens
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Mar 13, 2009 | GE Microwave Ovens
Sparks in oven
the burning is normally caused by a small particle of food getting stuck on the waveguide cover, this then carbonises and starts to arc. replacing cover should return oven to normal
Feb 22, 2009 | Sharp R-1480 Microwave Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
163 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
