Question about Panasonic RR-930 Microcassette Transcriber
How to fix stuck Tape Counter panasonic rr-930 transcriber machine
Tape counter will not move while tape moves. It is stuck.
4 Suggested Answers
  • 18 Answers
SOURCE: My Panasonic RR-930 transcriber speeds
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Posted on Jul 28, 2011
  • 145 Answers
SOURCE: Panasonic Model RR-930. The machine will not
Check that the pause switch is off. Otherwise, either the belt is broken or the motor is bab.
Posted on Aug 02, 2011
Testimonial: "Thanx so much. I was in a rush to get a job done and didn't realize that I pushed the PAUSE button..."
  • 145 Answers
SOURCE: the backspace on my Panasonic
There is a switch on under the tape deck that wears out or comes loose. This is something that needs service. We can fax it. 8663219780
Posted on Aug 16, 2011
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
After erasing a tape I have a high pitched noise when I step on the foot pedal
If it works fine otherwise, I wouldn't spend much time worrying about it.
You might want to clean the heads and the capstan.
Jun 01, 2014 | Panasonic RR-930 Desktop Cassette...
The sound is very faint even with the volume turned all the way up.
When you open the cassette door, there is a metal piece in the back that pushes the tape ajainst the head. If that is broken or bent, you can get low audio. Other possibilities are a dirty tape head or misaligned head.
Aug 01, 2011 | Panasonic RR-930 Desktop Cassette...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
I press on the footpedal but the tape does not turn. It only reverses.
Hello sorry but Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problemyour unit need to be send to service you can try this guys are really good.
Feb 04, 2010 | Panasonic RR-930 Desktop Cassette...
Tape Counter
Thank you.  The machine has a reset button that brings the counter back to zero. Still not sure it is working right but I'll see as I transcribe my tapes.
May 19, 2009 | Sony BM-840T Desktop Cassette Transcriber...
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-930 Microcassette Transcriber Logo
Top Panasonic Radio Communications Experts
Jason
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
