Square root of 95 to the nearest thousandth - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
9.747
Posted on May 06, 2014
  • 7993 Answers
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
  • 14 Answers
SOURCE: Square root
It may be that you have somehow changed to a 'mode' that only shows integer values.
Try pressing the green button, then 5, then 9. Then try the calculation again.
If this fails, you can use Google as a calculator - search Google for sqrt(0.4053) and see what happens.. :-)
Posted on May 28, 2010
  • 7993 Answers
SOURCE: i dont know how to
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Posted on Jan 14, 2012
SOURCE: How do I get the
I got the FX-9860GII and it shows up as decimal aswell, how do I change it?
Posted on Sep 06, 2012
  • 262 Answers
SOURCE: convert square root to decimal TI-30XA
Press 2nd then F--D key(its means left arrow key or left key from zero)
Posted on Feb 24, 2013
7.2468901 rounding nearest thousand
I assume you want to round it to the nearest thousandth.
Step 1 - identify the thousandths column - going to the right of the decimal are tenths, than hundredths, than thousandths
Step 2 - check the number immediately to the right of this column
Step 3 - if this number is 5 or greater, add 1 to the thousandths column
Step 4 - if this number is 4 or less - no nothing
Step 5 - delete all numbers to the right of the thousandths column
In this case the 8 is greater than or equal to 5, so we add 1 to the 6 to get 7 and then delete all the numbers to the right.
I get 7.247.
Good luck.
Paul
Oct 27, 2015 | Office Equipment & Supplies
How do you round 3.51795813 to the nearest thousandth
3.51795813
0.12345678
See the above line. The numbers relate to negative powers of ten.
1/1000 is 1x 10-3
Therefore the nearest thousandth is to three decimal places, which is 3.517, though since it is followed by a nine, which is greater than 4, the 7 then has 1 added to it and becomes 8.
The answer, therefore is 3.518.
Mar 10, 2015 | Office Equipment & Supplies
How do i round a number to the nearest thousandths if the number stops at thousandths
Do nothing. The number is already rounded to the nearest thousandths.
Sep 29, 2014 | Computers & Internet
How do I do math problems estimate roots
To do them it REALLY helps if you remember Perfect Squares.it will make you quicker at doing these problems.
From this page http://www.gmathacks.com/mental-math/estimating-square-roots.html
I have copied a section below.
For these problems.....
you don't need the exact answer! An approximation is good enough
. Memorize Squares
For all sorts of reasons, you should memorize perfect squares at least up to 12^2 = 144. It helps to know additional round numbers, such as 15^2 = 225 and 25^2 = 625.
Once squares are burned into your memory, estimating square roots is easy. Let's go back to the square root of 39. The nearest perfect squares are 36 and 49, which are squares of 6 and 7, respectively. Thus, the square root of 39 is somewhere between 6 and 7. Since 39 is closer to 36 than to 49, the square root of 39 is closer to 6 than 7.
Sure enough, the square root of 39 is about 6.24. You will never see a problem on the GMAT where you need to know that the square root of 39 is 6.24. But you may well need to know that the square root of 39 is a little bigger than 6.
We all had to learn these at one time.
Give it a go friend :) You won't regret it.later on in life.
Sep 10, 2014 | Office Equipment & Supplies
What is 24,270 to the nearest thousandth
To the nearest thousandth, it's 24,270 (or to be more precise, 24,270.000).
To the nearest thousands, it's 24,000 (twenty-four thousand).
Dec 16, 2013 | Office Equipment & Supplies
Round to nearest thousand
Step 1 - identify the thousandths column - going to the right of the decimal point, we have the tenths column, the hundredths column, and the thousandths column
Step 3 - if this number is 5 or more, add 1 to the thousandths column - if this number is 4 or less, don't add 1 to the thousandths column (leave it alone)
Step 4 - erase all the numbers to the right of the thousandths column.
In this case, the number in the thousandths column is 4. The number immediately to the right of it is a 0. Since the 0 is 4 or less, we don't add 1 to the thousandths column. Now we erase all numbers to the right of the thousandths column. I get 22.524.
Good luck.
Paul
Oct 17, 2013 | Office Equipment & Supplies
Round the DECIMAL number to the nearest thousandTH 2.44224
Round to three digits after the decimal point, so this is 2.442 .
The first digit after the decimal point is the tenths, the second the hundredths, and the third the thousandths.
Apr 06, 2013 | Cars & Trucks
Convert square root to decimal TI-30XA
Feb 23, 2013 | Texas Instruments TI-30XA Calculator
How can i round off the nearest thousands
Do you mean round off to the nearest thousandths? The thousandths place is the third place to the right of the decimal point. An example would be 0.001. In this case you have a 1 in the thousandths places which would be stated as one thousandth. To round to the nearest thousandths place you would look at the number in the ten-thousandths place and use that to determine what the number in the thousandths place should be. For example, if you have a number such as 0.1234 your answer, rounded to the nearest thousandth would be 0.123 because 4 is less than 5 and therefore you would round down. If you have a number such as 0.1235 your answer would be 0.124 because you always round up if the number in the next decimal place is 5 or higher.
I hope this helps.
Jun 27, 2011 | Computers & Internet
15 people viewed this question
jasbo
jasbo
