Question about New York Wire Office Equipment & Supplies
Coolroom compressor repair video - New York Wire Office Equipment & Supplies
There is a clicking noise that happens every few minutes from the bottom of the back of the refrigerator and it is no longer cooling in the freezer or bottom refrigerator part. Can it be repaired?
Just a simple relay failure. Pretty easy fix if you have a few tools. The relay over time just falls apart inside and makes a sound like a salt shaker. themobilian_2776.jpg
This just slips onto the compressor and powers all circuits inside the compressor to get it going and then it kills power or drops out half the windings.
Repair video
Aug 07, 2011 | Whirlpool ET1MHKXM Top Freezer...
Compressor is not running. I opened the cover and feel the compressor it is not running
Made a video of compressor replace on ge monogram. Maybe You don't need to change compressor, but just check how machinery compartment made. Location of components. I hope that was helpful.
Jul 26, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Went i turn on the air conditioning the back is blow air out but not the front
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
May 05, 2011 | TMI Products VizuaLogic...
How do I install compressor for amana refrigerator. Can a home handy man install a compressor? Do I need freon?
Hi.The compressor motor is connected to the refrigerant system, which is not user serviceable. It will be necessary to have the compressor serviced, or replaced by a qualified technician. During this process, the pressurized system will need to be re pressurized. This will require special tools, and regulative equipment, as well. This can be very dangerous, and that is why I prefer to give proper advise on this type of repair. Kindly, contact your nearest service tech.
Nov 26, 2009 | Amana ABB2223DEQ Bottom Freezer...
How to replace ac compressor
I'm not sure if this will help, but this: www.wonderhowto.com
has a video how to repair a vehicle ac and cooling system.
http://www.wonderhowto.com/how-to/video/how-to-repair-a-vehicle-s-ac-and-cooling-system-102457/
Aug 03, 2009 | 1995 Nissan Maxima
Paragon 8145-20 defrost timer
I am not professional at commercial refrigeration, and can't answer your question directly.
However, you can see 8145-20 240V defrost timer wiring diagrams and manuals on following link.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145 timer is time initiated, and pressure/temperature terminated, with back-up time termination.
Jun 28, 2009 | Paragon 8145-20 Defrost Timer
Have bought desmon coolroom FRI171723 BUT mislaid instruction manual
have bought desmon coolroom fri171723 but mislaid instruction manual
Nov 04, 2008 | Refrigerators
62 people viewed this question
Top New York Wire Office Equipment & Supplies Experts
jasbo
jasbo
Are you a New York Wire Office Equipment and Supply Expert? Answer questions, earn points and help others
