Question about Haier XQBM22-C Top Load Washer
Where I can buy filter WD-2800-01? - Haier XQBM22-C Top Load Washer
My hard drive stop data transfer for a few seconds and then strats it again - drives me crazy when listening to music from the drive
Copy one of the "music" files from the W.D. to your 'C:' drive.
Then, "play" that copy of it. If it stop/starts/stutters, it's your computer, not your W.D. device, that is the problem.
Otherwise, you have a problem with your W.D. device.
See: http://support.wdc.com/product/downloaddetail.asp?swid=119&wdc_lang=en
and "Download the Data Lifeguard Tools software (Acronis True Image WD Edition and user manual and the WD diagnostic tool)".
Run that WD Diagnostic Tool, to "test" your W.D. drive.
If it "fails" the test, then exercise the warranty to get W.D. to replace the drive.
If the warranty has expired, W.D. has a "Customer Loyalty" program;
buy a new W.D. drive through the W.D. web-site, at a discount.
Or, open the case, remove the disk-drive, and buy a replacement, compatible, disk-drive, and "transplant" it into your case, to revive your external storage device.
Dec 04, 2010 | Western Digital My Book Essential 1TB...
It starts but it shuts off immedially.
Here is the long answer with everything we learned while using a power washer twice a day for years::
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 01, 2010 | Karcher 2500 PSI Pressure Washer
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
Buying suzuki rm450z
hi mate there is nothing to look out for except how you ride it and handling the power butthe most important is maintaining you must buy this stuff to maintain your crosser {SILKOLENE PRO 4 PLUS 5W-40}{SILKOLENE FOAM FILTER OIL}{OIL FILTER}{AIR FILTER}{SILKOLENE CHAIN LUBE} AND SPARK PLUG ALSO MAYBE SOME WD40
BASICALLY CHANGE EVERYTHING BEETWEEN 3-5 RIDES CHANGE THE OIL IN ENGINE THEN REFILL TILL OIL HIT 1/2-3/4 ON SIGHT GLASS ALSO PUT THE NEW OIL FILTER IN WHEN THE OIL IS DRAINED. AND TO CLEAN YOUR AIR FILTR USE PETROL RINSE IT OUT THEN LET THE PETROL DRY OUT THEN GET THE FOAM FILTER OIL AND DUNK THE FILTER IN THIS USE GLOVES THOUGH ITS VERY STICKY STUFF THEN CHANGE THE SPARKY JUST UNSCREW AND PUT BACK IN THEN JUST START IT UP WITH THE REAR WHEEL IN THE AIR AND PUT IT IN GEAR AND JUST SPRAY THE CHAIN WITH LUBE AND JUST GET WD 40 AND LUBRICATE THE CLUTCH LEVER THE BRAKE JUST ALL THE JOINTS. YOU HAVE A NICE BIKE MATE FAST AS HELL VERY EASY TO GET ON BACK WHEEL
Aug 30, 2009 | 2005 Suzuki RM-Z 450
Can't find the oil filter on 1998 chevy blazer
there is a black cover right under the front of the blazer tha says oil filter acess
Mar 21, 2009 | 1998 Chevrolet Blazer
Fan stopped red light blinking
1. Unplug power to set, Remove filter, clean filter, replace filter.
2. Hold in reset button on front of set with set powered off for about two minutes.
3. Plug in the set, green light flashes for about a minute and goes off. Turn set back on.
4. If you think you need to buy a new power supply go to Mouserelectronics.com. Roger R. R.
Mar 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 air filter cover open error 33, FD connector?
connector locared on filter cover . back of metal filter .....
very small conector ........
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lg privilege 1,96ft3, washer&dryer combo model:WD3243RHD. Start working but dosen't take wather. I belive drain pump is gonne. Where to buy part. I'm from Canada.
Find nearest service center @ http://ca.lgservice.com/index_b2c.jsp BUT FIRST,.... if your LG WD-3243RHD (note dash is part of this model number) is not pumping out check the filter. Filter is located behind the small access door at the lower left on front of the machine. (There will be some water in the pump area)
Sep 20, 2008 | Washing Machines
Haier XQBM22-C Top Load Washer Logo
23 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
