Question about Philips Televison & Video
Geforce gt 430
Video shows but no hdmi audio, tv model 37PFL5332/78
  • 254 Answers
SOURCE: Problems establishing audio output from DVD RW to TV
check out is the socket in which wires are been inserted are loose internally.if yes then the loose socket needs internal soldering.
Posted on Apr 05, 2009
  • 39 Answers
SOURCE: ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Posted on Apr 22, 2009
  • 811 Answers
SOURCE: I am replacing my NVIDIA GeForce 8500 GT Graphics
If it is connected it will come loose. I believe it is for the cooling fan on the card. Be careful with pulling it out it is just a two part deal. You may pull the plug but it will also come off maybe in two pieces or one whole piece. Whichever it will come off. Give it some pulling. John
Posted on Jan 17, 2011
  • 22 Answers
SOURCE: I have an RCA home theatre...model rt2910. I have
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Posted on Feb 28, 2011
  • 13433 Answers
SOURCE: NVIDIA GeForce GT 240 fan stopped
The fan is probably stuck possibly because of dust or the fan is broken, you can purchase a cheap heatsink / fan from a retailer, or actually it may be easier and cheaper to just purchase a new videocard, they cost a little bit more than a fan. If you don't need anything better than a GT240.
Posted on Jun 11, 2012
Testimonial: "The problem was that the fan did not come on. Whenever I used both the VGA and the HDMI is shutdown. The card was hot. I suspect that there is a thermal cutoff. Rather than replacing the fan (and possibly finding out the fan is fine, but not getting power), I purchased a new card with more memory for $40. Thanks"
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Aug 24, 2014 | Computers & Internet
No son gt 630 on tv with hdmi
go to the sound icon on the taskbar with right click then open playback devices and again with a right click on the device you need the audio to come out set as default. You can even test if the output is right.
Aug 16, 2014 | ASUS A8N-SLI Deluxe Motherboard
Palit geforce gt630 not recognized windows 7
Hi, you probably need to enter the bios and select ,turn on, the pci-express option. This graphics card has a good record of working well with Windows 7.
Feb 09, 2014 | Palit Microsystems Palit nVidia GeForce GT...
Driver download
drivers are avaliable on the nvidia website
Sep 16, 2013 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
I have a Galaxy GT 430 1GB graphics card and I installed into the PCIe x16 slot. But when I boot up my computer, it locks up in POST. I can see that my computer recognizes the graphics card because a...
If you had a graphics card prior to this one make sure all software from previous card is uninstalled. If you installed your card correctly, it should come up normally then, you can run your installation cd. If it is not coming up properly, see if you can start in "safe mode", go to "device manager", click on the box next to "sound , video, and game controllers", then click on your card and in the list make sure you see "disable". If you see "enable" click on that and exit, then restart. You should now be able to run your cd. If you had prior software and didn't uninstall before the install of new software, you may have to start over. After your original install from cd you can get all prior updates from Nvidia
http://www.nvidia.com/Download/index.aspx?lang=en-us
Apr 25, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Are there linux drivers for this card?
http://www.nvidia.com/object/linux-display-ia32-260.19.36-driver.html
Feb 21, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
