Question about Sewing Machines
Where is the tension knob on a Singer 4832C? - Sewing Machines
5 Suggested Answers
SOURCE: how do you remove cover from Singer 7462
I found that by turning the machine over on its back I could lift the front cover from the bottom and get it over the tension knob.
Posted on Mar 29, 2008
SOURCE: Hi - I'm in the market for a sewing machine. I'm
I used to sell necchi's, I have used necchi's for over 30 years for sewing & quiting. I own a necchi model 4595 mechanical sewing machine, & a omega by necchi, model 6150, electronic, my husband does his quiting on it.I have made clothes & quits on both machines
I have never sold or tried a necchi 3205fa or a singer 4832c
all I ever had were old singers, which I have gotten rid of all them
make sure it has a operation manual with it.
make sure you can take it back if something is wrong with it.
happy sewing
Posted on Jul 30, 2010
  • 11 Answers
SOURCE: Singer 6105 Tension knob
First make sure that the thread you are using in the bobbin is the same brand and type as in the spool that is threaded. I've read that using different weight threads at the same time can cause tension problems. I have actually had this problem and following this advice it went away. If this doesn't work you may need to have the machine serviced, unless someone else in the forum can advise otherwise. Good luck.
Posted on Jan 14, 2011
SOURCE: singer 413 tension
singer has a free manual for the sewing machine,, here's a link
http://www.singerco.com/uploads/download/05cd53760826209952d04b99bc6962f8ea588653.pdf
Posted on Oct 22, 2012
I have a Singer 6105 and the thread tension knob has fallen off. How do I fix it?
that is how most of them work . a small dab of glue will keep it in place
Feb 24, 2017 | Singer Sewing Machines
I have no tension at all on my singer 8734
try some unwaxed dental floss to clean the tension knob.
May 19, 2014 | Sewing Machines
Need to know what the knobs are for
Are you sure that it's a Singer LS-1217? I can't find any model with 1217 on the Singer site.
The Brother LS-1217 manual is available here: http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_top.html?reg=eu&c=eu_ot&lang=en&prod=hf_ls1217euk . The direct link to the English version of the manual is http://download.brother.com/welcome/doch000000/ls12171217b13171417ug01enesfrpt.pdf . There are only a few knobs on most machines. On the front near the needle is the Needle Thread Tension knob. If you use contrasting colors (different top, bobbin and fabric colors), you might see a straight stitch where the top thread is visible on the bottom of the fabric for example. Adjust the tension to get both the top and bobbin threads meeting in the middle of the fabric layers. (Increase the needle thread tension - rotate to a higher number but go in 0.5 increments.)
Then you have near the motor area the stitch width and length knobs. The width is only for zigzag stitches. A long stitch length is good for a temporary seam (like basting in a zipper or hem) before you finish that area. However, the width and length should be adjusted depending on the fabric. A fine fabric needs a smaller stitch, usually. The knob on the right side of the machine is the balance wheel (or hand wheel). This adjusts the needle height so that you can have the needle out of the way while changing the bobbin, for example.
I hope this helps.
(I use the Singer Sewing Book as a reference for tension issues.)
Feb 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
How to balance zigzag thread tension in singer 5830C sewing machine
if you try to regulate the tension & it doesn't respond then the tension dial may need to be replaced
Mar 15, 2012 | Singer Sewing Machines
Singer 9217: I have the tension lever all the way down to + and the stitches are still too loose. What can I do?
try reversing the tension & see if that help if not the tension knob may be damaged & have to be replaced
Feb 03, 2012 | Singer Sewing Machines
I have a Singer 9910 machine and I cannot get the thread tension correct. Every time I try and sew it bobbin thread is showing on the top.
Turn the tension knob to the left. Look at your manual and if you cannot find it, go to singerco.com and download it. Do not turn the knob too much each time or you will get it all messed up. Just a small amount each time.
Sep 09, 2010 | Singer Quantum 9910 Computerized Sewing...
Hi - I'm in the market for a sewing machine. I'm trying to decide between a Singer 4832C or a Necchi 3205FA. Which would u recommend? Thx.
happy sewing
Jul 23, 2010 | Singer 7442 Mechanical Sewing Machine
Model 4832c
guide the the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)If it doesn't work like this, then there is probably thread stuck inside the tension assembly. Set the tension to zero and blow hard between the discs to dislodge the thread. If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
Check to be sure you have the correct bobbin and that it is inserted the correct way.
OR remove the needle plate to remove the bobbin case. Look for any burrs or rough spots. Use a fine emery stick and steel wool to remove and buff them Reassemble and try again.
Sewman7
Jun 17, 2008 | Singer 7442 Mechanical Sewing Machine
How do you remove cover from Singer 7462
Mar 29, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
