Question about GPS
What causes dark spot on marine gps screen ? - GPS
2 Suggested Answers
  • 157 Answers
SOURCE: VHF Marine handheld Transcever GPS bad screen
Hello jmartin1. I need some more info, Mgfr., model & serial#. You maybe able to replace the display yourself. The heat could be caused by no air flow inside unit or dust/corrosion bulidup, mabe solved by cleaning.
Posted on Oct 20, 2008
My vizio 32in. tv. year 2007 has a dark faint cloudy spot. whats the cause and how to fix
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 25, 2016 | Vizio Televison & Video
How to fix dark spot in middle of screen on led smart tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 20, 2015 | Vizio E701i-A3
Screen dark
when on sattelite screen (it starts on that screen) push left button to diminish screen brightness. The screen should return to a non-perfect, but readable state. No idea what is causing this problem or how to definitively resolve it.
Feb 28, 2014 | Garmin GPS 12 GPS Receiver
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
How do i insert a coordinate to find a spesific fishing spot
The Garmin nuvi's were designed as automotive navigators and not really designed to be used as marine or outdoor GPS units with the exception of the nuvi 550 which is an all around GPS.
The Garmin handhelds are recommended for marine and off road recreational use but it is possible to navigate if you know the coordinates of your fishing spot.
To enter coordinates: Touch Where to? > Coordinates and touch a box to enter a coordinate.
You can also refer to the manual for more information. nüvi® 215
Sep 22, 2011 | Garmin nuvi 215 GPS Receiver
The screen on our gps is messed up! Either it got
You would have to send it to Garmin unless you found a Marine Electronics dealer that had an old display in their shop. They could then replace your display. Good luck!
May 22, 2010 | Garmin Gpsmap 5012 Touch Screen...
I have a Lowrance 7200C GPS (marine) unit with a "Navico 041-0680-17 chip. It doesnt show the depth contours, is there an upgrade or do I buy another chip? and if so, what chip will be best for my unit?...
Not showing the Depth Contours usually means it doesnt have that programmed on the chip.
The best Chips Ive ever seen, used or worked with for the Lowrance's are the "Navionics" and Fishing Hot Spots. Both can be obtained from Cabela's...either retail or online. And normally go from 99bucks for last years maps to 199 for this years. Hope this helps.
Oct 15, 2009 | Lowrance Globalmap 7200c Gps 7" Screen...
Sep 29, 2008 | Uniden Mystic VHF / GPS 2-Way Radio
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
GPS Logo
15 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
