Question about Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F
Why does the red light on my VF70 freeze r stay on all the time?
The freezer frosts up very quickly after de frosting needs doing again soon after
    Master:
  • Zanussi Master
  • 480 Answers
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Why does the red light on my VF70 freeze r stay on - 24341613-zd1td1vvrl1llkwzbg5ljqsk-5-0.jpg
Dado
Posted on Oct 04, 2015
3 Suggested Answers
brainyass
  • 242 Answers
SOURCE: Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Posted on Oct 24, 2008
  • 4793 Answers
SOURCE: Our freezer has devoloped a problem in that it
the unit was still wet inside when you switched on the fast freeze,hence the frost and ice.
Posted on Aug 18, 2010
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
I have a TALL PHILLIPS FREEZER ABOUT 20 YRS OLD. IT ICES UP VERY QUICKLY. THERE IS A STAR ON THE RIGHT WITH AN ON OFF SWITCH WITH A RED LIGHT.. ON THE LEFT IS A SMALL ROUND BUTTON WHICH NEEDS A COIN TO...
There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
The other cause and type of frosting is automatic defrost failure.
Mar 31, 2011 | Freezers
I NEED TO KNOW QUICKEST WAY TO DEFROST AND WHEN RUNNING NORMALLY
the SAFEST way to defrost your refrigerator, is to unplug, open both doors, and blow a fan for 24 hours. Doing anything other than this, in order to "speed it up" can cause SERIOUS damage to the unit.
Keep in mind, this is ONLY a temporary fix, unless you fix your defrost problem, you will have to do this again in 7-10 days, repeatedly
Apr 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Indesit c239 freezer not getting cold red light constantly on
If you take the rear cover off the inside of the freezer you can see the evaporator coils. observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 15, 2009 | Freezers
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 | Freezers
Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F Logo
254 people viewed this question
Top Zanussi Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Dado
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
