Question about Ruud Heating & Cooling
INSIDE FAN WILL NOT COMEON - Ruud Heating & Cooling
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 135 Answers
Bad capacitor or bad fan motor or bad wiring
Posted on Sep 01, 2014
Door ajar light and dome lamp comeon occationally while driving
These have no button type switches. They are located in the door latch inside the door. Just unhook the plug at the door post under the rubber cover one at a time to find wich one is faulty. you will need to trick the door switch by manually closing the lock on side of the door. Do one at a time. That's what I did.
Apr 13, 2013 | 2003 Dodge Neon
Outside fan on heatpump not spinning
Are you cooling or heating? In the cooling mode the fan should run with the compressor. Shutdown, open up control section of unit, check Capacitor. Try to turn fan blades by hand. Does it spin freely? Do not touch capacitor terminals until you discharge it by shorting terminals to ground. If the capacitor looks swollen then it is bad.
Aug 08, 2011 | Heating & Cooling
Yesterday the picture froze and then went black. The DVR then the fan came on and only one green light on the front and nothing else. Tried to unplug and restart but more of the same.
Hi my name is Mike Houston of DISH Network and Isee where the picture froze and then went black. If you have done a Hard Resetand allow it to power back up, after 10 minutes you do not have anything comeon the screen I will need you e-mail me with your account number or phonenumber. michael.houston@dishnetwork.com.
May 30, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Why is toyota camery backup lights such a problem? my reverse lights do not comeon...brake lights work fine.,..but i have no lights rear..when driving. i have no clue of where or how ot repair a switch and...
more likely than not the bulbs are bad remove the tail light assy inside the trunk you should see the wingnuts to turn then slide it out and replace the bulbs your olcal autoparts will do this for you if you ask nice
Feb 09, 2011 | 1998 Toyota Camry
Light not coming on when I turn the switch on. only parking light comes on . Headlights comes on for short while then goes off. Sometimes playing with the switch cause it to comeon for a split second.
your description is consistent w/ a failed headlamp switch. the other remote possibility is a poor connection at the headlamp switch (this is very unlikely unless someone has been inside the dashboard recently)
Sep 29, 2009 | 1999 Dodge Caravan
Will not comeon jsut keeps flashing a red light ?
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 29, 2009 | Kodak EasyShare C310 Digital Camera
Kds-r6oxbr1
I had the greenish tint problem and the service technician came out and replced the optical box for free under the sony extended warrantee. The technician exlained that the optical box design gets too hot and destroys teh first LCD screen nearest the bulb (green). The new optical blocks have a filter lense placed in front of the green LCD screen to try to cut back some of the heat so it doesn't happen again.  After he left, we started getting the intermittent porblem of the set shuttng down after 2 seconds of picture and the red light flashies four times.  For a few weeks, it would eventally come back on if tried a few more times, but last week it just wouldn't comeon anymore.  I called the technician and he said that the sets that had the optical box problem, oftern had this problem because the excess heat warped the door on the light. there is a little plastic pin on the door near the screw that goes into a whole in the set and triggers a micro switch, which is intended to make sure the light doesn't comeon if the door is not completely closed. When the door warps just a ittle, the pin does not engage the micro-switch enough and the set thinks the door is not installed.  I opened the door and closed it again, making sure it was firmly seated and teh screw was tight.  the set started right up like normal.  He said he has ordered a new door and will drop by and put it on when it comes in.....also complete;ly covered by the Sony extended warrantee for teh optical box problem.  Hope this helps.  The set has a better picture than any other projection TV I have seen....when it works. I am still glad I bought a Sony because they have stepped up and taken responsibility for this obvious design flaw on a $4K TV.  What amazed me is all the postings I read where people have no idea why this is happening. My technicain said he changes a couple of optical blocks a week and knew immediately that the warped door was the four red light problem. He has changed so many, that he said his first time it took almost 3 hours ( all the guts of the set have to come out to get the optical box out...not something i would recommend for the amateur), but now he does it in 45 minutes.....which I witnessed. He also took the time to vacuum out allthe inside of the set when he had it all apart. Loquatius
May 04, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Dose not come on
Your DLP lamp is out.... Order one online and install it yourself. Instructions are in the owner's manual
Jan 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
