Question about Bauknecht 24 in. GSX7551 Built-in Dishwasher
Bauknecht remove OVEN door - Bauknecht 24 in. GSX7551 Built-in Dishwasher
Where can I purchase a replacement drum paddle lifter for my old bauknecht tumble dryer TRA965?
HELLO.
The best way to get the drum paddle replacement is to visit the manufacturer website to order for it stating the microwave oven model number and give your house detailed address.
However the
drum paddle can also be purchase at any microwave oven authorized dealers around your local area with the model number for compactibility(easy use).
Thanks
Sep 21, 2011 | Microwave Ovens
I have a Bauknecht Fridge freezer with icemaker (type E25SSA) and the icemaker has stopped working. Is there a registered Bauknecht repair agent who can call out to Northwich. The repair is covered under...
dear sir i have the model ksn6500 and when we oen the door we hear something thinking like something want to start,the fridge is working properly but the noise is continous
Jan 17, 2011 | Freezers
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
Mar 20, 2010 | Whirlpool GBS277PDS Electric Single Oven
Bauknecht Mod. BSC 1000 nothing working. Checked fuses - is there a switch/fuse on the oven that could have blown?
THERE IS A THERMAL SWITCH ON THE OVEN INSIDE FOLLOW THE POWER CABLE TO THE CONTROL SWITCH. MOST OVENS HAVE A THERMAL SAFETY INSIDE THEM INCASE THEY GET TO HOT
Mar 08, 2010 | Baumatic B187 Stainless Steel Electric...
Bauknecht GF7199 F7 light has come on
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the door and turn on the power. then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Hope this helps .
Mar 06, 2009 | Bauknecht Dishwashers
Dishwasher
have only worked on them a few times but no problem to use. literally select program, close door and start. you won't break anything by trying it out.
put detergent in the dispensor and rinse aid in the rinseaidv despensor. if in a harrd water area, add dishwasher salt to the softener
Aug 14, 2008 | Bauknecht 24 in. GSF8971 Built-in...
Dishwasher tripping electrics
Check the wiring between the door where it goes underneath. Sometimes it will wear and short out. Another possible solution If you can see the dry element feel it for holes or missing pieces. If it burns out it will usually short out just like the oven element on an electric stove.
Jul 01, 2008 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht 24 in. GSX7551 Built-in Dishwasher Logo
Top Bauknecht Dishwashers Experts
ray gallant
michael mcdonald
Level 1 Expert
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
