Question about Vaultz VZ01002 Locking Cash Box
Combinatrinlockboxhowtounlock lost combination to my lock box. how do I open?
How do i fix lost combination?
sorry but you need to contact the mfg of it to get combination . we do not have them here
Jun 23, 2015 | Home Security
I have a 418-392 Brinks combination lock and don't have the combination
I have the same lock and a forgotten combo. Did you ever find out how to get it open and reset?
Jan 03, 2014 | Brinks 1-7/8 In. SS Dial Combination Lock
I forgot the combination to my master lock box. What do I need to open the box?
If you do not have the combination, try to contact the manufacturer directly. There may be a serial number on the lock that they can match the combination to.
If that does not work, you will need to contact a locksmith.
Apr 20, 2011 | Master Lock : Locking Combination 5-Key...
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
Lost combination to nu set lock box . I would like to open the box and be able to reuse it.
You can dial all the combinations (1000) in a couple of hours while you watch TV. I just did one (2012 version with letters) and hit about half way through. The problem is going to be a lack of a key. You won't be able to open the shackle on some versions and won't be able to reset the combination (same key for both functions).
Nov 20, 2009 | Locks & Locksmithing
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
I lost the combination to my APC PNOTECL5
Call customer support. If they can't do anything, look up combination lock cracking on the internet.
Jun 03, 2009 | APC PNOTECL5
Vaultz VZ01002 Locking Cash Box Logo
79 people viewed this question
Top Vaultz Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vaultz Office Equipment and Supply Expert? Answer questions, earn points and help others
