Question about Genius 31030068106 Ring Presenter/Controller USB Pico Receiver 2.4GHz 1250dpi 5Buttons Black Retail
Where can I find a replacement USB Pico Receiver 2.4GHz?
Wifi password cannot acpect
Is it case sensative? Are you sure you did input the correct password. Some networks have different passwords on 2,4gHz / 5gHz
Apr 26, 2014 | LG GT540 Cell Phone
I have a Mitsubishi 55 inch model WS B55 with blinking green light. Already replaced DM caps. Does any one have any ideas on what else to do.
Yes, either check the 3 pico fuses in the DM or:
First thing to do is remove front speaker grill--it shouldpull out and is secured with plastic pegs--behind it you will find aninspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Mar 26, 2012 | Mitsubishi Televison & Video
Connecting Pico projector to a Laptop...
sorry dude the usb is for charging only you need to buy a vga to composite cable and a male to male component cord both purchaseable from this web site http://www.bestofferbuy.com
Dec 16, 2009 | Optoma Pico PK-101 DLP Projector
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Power Suply Replacement
Any good computer supply company should handle power supplies. The important thing is to get one rated for the same power. (300W, 350W, 400W, etc.) You can always go higher, but not lower.
Oct 18, 2008 | Computers & Internet
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Mouse not working after BIOS upgrade on Intel D845GRG motherboard
use usb mouse
othervise re format yours whole system low level
and re install win xp or whataver you want
Dec 14, 2007 | Computers & Internet
Genius 31030068106 Ring Presenter/Controller USB Pico Receiver 2.4GHz 1250dpi 5Buttons Black Retail Logo
52 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
