Question about Thule 2008 Dodge Dakota - Quad cab - Xsporter Truck Rack
2008 dodge dakota blower motor not working - Thule 2008 Dodge Dakota - Quad cab - Xsporter Truck Rack
How do you replace blower motor 97 dodge dakota
The Durango is the same chassis so the instruction at the link on youtube will work. How to Install Replace AC Heater Blower Fan Motor Dodge Durango 04 09...
Dec 08, 2016 | 1997 Dodge Dakota
A//c unit works only on high speed/
blower motor resistor...it cuts power to lower settings...easy fix usually under passenger side glovebox two screws and harness looks like a metal card with plastic bottom...
Jan 28, 2016 | 2004 Dodge Dakota
Where is the heater resistor on a 2005 dodge dakota? Behind glove box?
should be just above the blower motor. You will need to remove the glove box door to gain access.
Dec 12, 2015 | 2005 Dodge Dakota Club
Heater blower motor not working for dodge dakota 2004 4x4 4.7 quad cab
try picking up a blower motor resistor, about 10-20 dollars at a local part store. then check this blog out. I have replaced 4 in my 2004 dakota, Takes about 10 minutes to replace, located on passanger side of truck above floor.
http://www.dakota-durango.com/forum/showthread.php?t=65326 WORTH READING AND HAS PICS !
Jan 07, 2011 | 2004 Dodge Dakota
The fan motor switch in my 1990 dodge dakota does not work. I have checked the blower motor out and the fuses out. and the resistor out. they all are fine. I am not getting any juice to the fuse box for...
Have you checked the blower motor resistor. Usually locate in the blower box with a plug on it. Has 2 bolts holding it in. Take out and inspect.
Nov 24, 2010 | 1992 Dodge Dakota
Hi ya, i just inquired about my blower motor, is the relay and switches and everything under the dash or under the hood,
In the Dodge Dakota the blower motor resistor is located under the hood, on the right side firewall.
Dodge Dakota Blower Motor Resistor Location:
Dodge Dakota with a complaint of no blower operation. After unplugging the harness connector and removing the two screws, you could remove and examine the resistor coils for damage. The heat and subsequent rust damage are clearly visible in the picture below.
Apr 07, 2010 | Dodge Dakota Cars & Trucks
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Feb 04, 2010 | 1987 Dodge Dakota
2002 DODGE DAKOTA, BLOWER MOTOR QUIT, CHECKED FUSES, REPLACED MOTOR, REPLACED RESISTER, STILL DOESNT WORK ?????
if u changed all of that then it should be the heater control . have u given direct power to the blower motor? it is possible that its faulty.
Jan 25, 2010 | 2002 Dodge Dakota Club Cab
1992 dakota- blower motor willnot work. a/c was on
Check the connections at the blower resistor.
May 13, 2009 | 1992 Dodge Dakota
1997 Dodge Dakota 2WD with A/C. 135000 miles. Blower fan stopped working after a period of working intermittently. How do I replace it? It seems to be buried behind the dash and the ventilation air...
Wait, before you change that blower motor try replacing the blower motor resistor.It is located on the fire wall on the passanger side, under the hood. Should cost about 10 to 12 dollars and take about five minutes.Dakota's seem to go through these regularly.
Dec 10, 2008 | 1997 Dodge Dakota
Thule 2008 Dodge Dakota - Quad cab - Xsporter Truck Rack Logo
65 people viewed this question
Top Thule Boating Experts
Tom Chichester
John Mabry
John Mabry
Richard Warren
Richard Warren
Are you a Thule Boating Expert? Answer questions, earn points and help others
