Question about Cycling
My garmin edge 705 will not awitch on - Cycling
shannongreer
  • 75 Answers
SOURCE: will the garmin edge 705
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
Posted on May 12, 2009
  • 67 Answers
SOURCE: how do i send a gpx file to my garmin 705 edge?
use a program called mapsource available from www8.garmin.com/support/download_details.jsp?id=209
Posted on Apr 19, 2010
  • 81 Answers
SOURCE: Garmin Edge 705 (just over 1 year old). Previously
your disk might be corrupted. May be the only solution is to format, with all data lost.
Otherwise try to plugg another SD in Garmin, and see result.
Be carefull that when removing (disconnect) a SD device, it must be ejected properly, otherwise it may be corrupted if a write operation is ongoing.
Posted on Sep 04, 2010
  • 81 Answers
SOURCE: I went to ride with my garmin edge 705 and it
Try Soft reset (procedure in the notice) or hard reset.
  • 81 Answers
SOURCE: cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Posted on Sep 25, 2010
How i can hard reset on my garmin edge 705
Hard reset : To perform this one holds down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Feb 01, 2017 | Garmin GPS
How i can hard reset on garmin edge 705?
Hard reset : To perform this one hold down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Garmin edge 705 will not turn on
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
Sorry but honestly...Since GARMIN launch the EDGE this problem is still not resolved by them. The EDGE 305 had the same problems. Just search the www and you will see. My 705 died on me after just 2...
Edge 205 or 305 or 705 or 605 often crash, then impossible to power on again.
Nov 01, 2010 | Garmin Edge 705 Handheld GPS Receiver
My garmin edge 705 will not turn on ?
Cant solve it. Buying Garmin --- get used to it not turning on. Problem since the launch of the EDGE models. Still a problem.
Feb 17, 2010 | Garmin Edge 705 Handheld GPS Receiver
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
The cadence sensor will not sink to my edge 705
Please perform pairing as described in you user's manual. Device must be paired before becoming available.
http://www8.garmin.com/products/manual.jsp?product=010-00555-20
Apr 05, 2009 | Garmin EDGE 705
Cycling Logo
93 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
