HP D330 PC Desktop Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My direct3d acceleration is disable ? i used windows xp sp2
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Jun 22, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
41186
Points
273
Well it seems that your direct3d accelerator is not working so you can reinstall .for more assistance you can visit----http://robs-tech.blogspot.com/2009/06/looking-for-free-technical-support.html
Anonymous
Level 2:
  • Expert 35 Answers
Anonymous
Expert
Level 2:
Answers
35
Questions
Helped
31813
Points
105
Maybe you haven't installed yet your video/graphics driver, install it and and reboot yoour computer. It might solve your problem.
I need 3D accelerator
Direct3D is a component of Microsoft's DirectX graphics software and is one of the more commonly used graphics accelerators in PC gaming. Of course, before you can enjoy the benefits of Direct3D acceleration, you need to have that particular component enabled in DirectX. Fortunately for your gaming needs, enabling Direct3D acceleration is not an overly complicated process, and can be achieved in a matter of moments. Open the "Start" menu and type "dxdiag" into the Windows Live search box, then press "Enter." This will bring up the "DirectX Diagnostics" dialog box. Click the "Display" tab. Locate the "Direct3D Acceleration" entry. Click the "Enable" option next to the Direct3D entry. This will turn on Direct3D acceleration. You may need to restart your computer to make the changes effective. Hope this helps. http://www.microsoft.com/games/en-us/aboutgfw/pages/directx.aspx http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance b> http://download.cnet.com/3dmark2001/3000-2121_4-10056689.html
I want to free download d3d driver with hardware acceleration for windows xp
You want a direct3D driver for - what video card specifically?
chances for Windows XP support is small.
2answers
No hardware-accelerated Direct3D device were found . this the problem appears when I open my game. help me to solve this problem. or give me this kind of device.
depending on the windows you are using, the accelerators should install automatically, or else the system does not support or you can download the accelerators form microsoft and install them.
2helpful
No hardware-accelerated Direct3D devices were found swithiching to the reference rasterizer a software device that implements the entire direct3D feature set but runs very slowly.
more info please
But basically your machine is not detected a 3D video card.
It could be that a proper video driver has not been installed (Windows is using a default) so this maybe cured by simply downloading the driver for your machines GPU.
This machine might be using integrated "onboard" graphics, in which case don't expect very good performance especially with any recent game.
2answers
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
I've been using my MP830 with Windows XP for years without any problems. I have all of the current Windows updates. I'm now getting this message: "prestopm.exe has encountered a problem and needs to close"
It has to do with your display.
Try this...
1. Click Start, and then click Control Panel.
2. Click Appearance and Themes.
3. Click Display.
4. On the Settings tab, click Advanced.
5. On the Troubleshoot tab, move the Hardware acceleration slider control to the third position (from the left), and then click OK.
Note The following message is the description for this position:
Disable all Direct Draw and Direct3D accelerations, as well as all cursor and advanced drawing accelerations. Use this setting to correct severe problems with Direct X accelerated applications.
6. Click OK to close the Display Properties dialog box.
DirectDraw and Direct3d Acceleration Problem
This problem happened to me when I was installing halo pc. Its not fixable so what I recomend is that you take all of your files, pics, ect. and put them on a hard drive or flash drive and start over on your computer. I had to do that because the direct x 9 got corupted and I was not able to fix it. Now that I completely formated my computer, I am able to play halo and halo 2.
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
3helpful
Direct3D hardware acceleration is disable
i can work any 3d game by my graphic card..........pls.
thanks
10helpful
4answers
Directdraw Acceleration no available (Disabled)
The same problem happened to me and following procedure solved it;
Goto Diplay Properties->Settings->Advanced->troubleShoot. On that window I saw that the hardware acceleration was set to None. I made it Full. And now dxdiag should show all options enabled..
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
