Question about Jules Jurgensen Fisherman 7485 Wrist Watch
How to take glass out of gold sovereign watch have stem out cant get glass out.
What is this womens 14 k gold watch worth?
Without more information, "only what someone will pay." The name on the face, or back, should be entered into a search engine and lead you to sites which sell watches, and show you pictures for you to match against.
May 14, 2016 | Watches
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
Nov 20, 2011 | Accutron Swiss Watch by Bulova 26B44
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
Feb 09, 2011 | Fossil FS3087 Wrist Watch
It is a lever set watch. I can't see how to open the face of the watch to see the lever. Serial # 1109313
what kind of watch is it?
some watch can be open thru the top glass (plastic) using a special tool. But theres a system for it to remove the stem and crown. most of them use a male and female stem.
its really a skill ...
Dec 14, 2010 | Watches
Can't get the back of my watch back on
mcdevito75 here, Your Timex watch back cover should have a cutout in the back cover for the stem (winder) make sure this cutout is lined up with the stem the stem lies in this cutout, once you have it lined up, lay the watch down, crystal (glass up on a sturdy surface, Table, counter top etc. Now, with your palm and even, even pressure on the crystal (glass) simply press down, you"ll hare it click shut. Don"t force anything and if you still can"t get your watch back cover on, look for a small watch repair shop in your arear. It may take a special pair of pliers to get the cover on. Most Timex back covers are kind of hard to get back on.
Jul 11, 2010 | Timex 27191 Wristwatch
How can you get into a sovereign ladies watch to change the battery, does the back come off or the glass ? the back doesn't seem removable. its diameter is 20 mm and its 9 carat gold. bracelet and watch
You have to pull stem out of watch movement completely and then remove watch glass. Sovereign watch cases are monoblock, so, the only way to get into it is to remove the glass. Rate me, plz.
Feb 10, 2010 | Watches
New watch..Jules Jurgenson day-date..the stem cap is loose.
remove the cap and put a tiny drop of locktite glue on it. spill some glue onto a piece of glass or an old plate and use a sewing needle to put a tiny drop of glue in the hole then screw it back on and wait till the remaing glue on the glass is gone hard before pushing the stem back in .. this last bit is important so as not to glue the stem to the watch. if this helps please rate me joe
Nov 12, 2008 | Jules Jurgensen 5004PB ( ) : Swiss Quartz...
Changing a watch battery
I used a sharp penknife blade to remove the watch front by getting right on the base and pinching the glass off, (comes off quite easily) tilt the watch out of the case and see enough to prise battery out with a needle. The battery is a Maxwell SR920W or equivalent. Have ordered new batteries on ebay.
Oct 04, 2007 | Watches
Jules Jurgensen Fisherman 7485 Wrist Watch Logo
14 people viewed this question
Top Jules Jurgensen Watches Experts
Jimmy Accardi
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
