Question about Medical
What does it cost to install a bathroom cabinet
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
How to find a good bathroom installer UK
Go to the internet and look up local general contractors, check out thier website and see if they are involved with that scope of work. If that fails check with your local plumbing supply stores and cabinet shop for contractors
Nov 24, 2012 | Home
What is the most common type of bathroom vanity?
Cabinet style vanities are the most popular style. They are mounted on the floor, along a wall and have a mirror installed above. Here is what a typical cabinet style bathroom vanity looks like -
Sep 03, 2012 | Belle Foret Furniture
What are some of the styles to choose from in terms of bathroom vanities?
There are three main styles of bathroom vanities - shelf vanities, wall-mounted vanities and cabinet style vanities.
Ground fault from box
In California It is code to have a ground fault receptacle where ever water is, Bathrooms, kitchen, laundry ect.
I have a older home that has 1ground fault for all receptacles located in the garage, so to update I have installed ground fault receptacles in all locations where water or dampness is present, even under the kitchen sink cabinets.
Apr 22, 2012 | Cars & Trucks
What would it cost to have a vent/fan installed in bathroom?
Learn the cost to install an fan by doing it yourself compared with the cost an electrician will charge. Installing a through-the-wall fan is an involved project that requires carpentry and electrical skills, so it's best left to the pros unless you have those skills.if you don't have , you should pay charge for service and the cost of fan .there is cheap and expensive fan .depends on yourself.
bathroom light
Apr 12, 2012 | Home
I have two bathrooms directly under each other. The hinges on both cabinets (under the sink) are rusted and the pipes going from the wall to under the sink are also rusted. There are NO LEAKS ANYWHERE in...
You can't stop condensation or humidity in the house, especially in the bathrooms. A few choices: replace the hinges, or oil the hinges with WD-40. Install a vent fan (even though you have a window) and replace the pipes with PVC pipes. Metal drain pipes will always rust, because they drain water. Replace all under sink drain pipes with PVC
Mar 13, 2010 | Home
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
Medical Logo
473 people viewed this question
Top Medical Experts
Electro Med Services...
Are you a Medical Expert? Answer questions, earn points and help others
