Question about 3Com 3102 IP Phone
Upgrade firmware on 3102 - 3Com 3102 IP Phone
I need to upgrade firmware on Mitel 5224 phones
you will need to search the torrents to find the firmware upgrade, Mitel have removed the firmware upgrade site to stop people from upgrading the firmware for SIP use instead of Minet, once you find the firmware you want then you upgrade it from a web browser.
Apr 30, 2011 | Mitel Computers & Internet
Looking for an updated firmware version for model WRT54G
Upgrading the router's firmware will give it numerous functions. This includes a more stable connection to the internet.
To upgrade the router's firmware, complete the following steps:
i. Downloading the Firmware
ii. Backing-Up the Router's Settings
iii. Upgrading the Router's Firmware
iv. Completing the Firmware Upgrade
v. Restoring the Router's Settings
vi. Completing the Firmware Upgrade Process
NOTE: Before proceeding with the upgrade, your computer must have an active Internet connection. It is also recommended that you use a wired computer in upgrading the router's firmware.
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Firmware upgrade was interrupted & now I can't connect to it. I have reset it 3 times & still nothing
TRY
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
Need manual for 3102FB Necchi
I found a 3102 here - http://www.sewingstyle.com/Necchi-Sewing-Manuals.html
However, I would check with the merchant before ordering to be sure it is the correct manual for your machine.
Apr 29, 2010 | Necchi 3102 Mechanical Sewing Machine
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Jun 25, 2009 | 3Com NBX 3102 IP Phone
3Com 3102 unable to connect to NBX 100
The problem is licensing for a 3102 phone. I doubt an old NBX 100 has a group 2 license. The 3102 requires a license to run unlike the 1102 or 2102.
Jan 07, 2009 | 3Com NBX 3102 IP Phone
Firmware upgrades
Installing/upgrading firmware is usally not requemented. You will not be adding any new feature to u're unit. There's no reason to do reinstall or upgrade the firmware other than to repair the unit in the event the units firmware is corrept.
Johnny Delstar
Apr 26, 2008 | Delstar DS 31024 MP3 Player
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
3Com 3102 IP Phone Logo
27 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
