Question about Canon DR-9080C Path-Through Scanner
Error no page in Feeder when there are pages in feeder
    Problem Solver:
  • 11 Answers
Need more information. Does the doc elevator lift the paper to the pick rollers? Check the plastic lever that is attached to the upper feeder cover. Make sure the upper cover is closed properly Verify that the dark colored sensor is clean in the feeding tray
Posted on Jun 11, 2014
SOURCE: No page was found in scanner when one was there
Lift up the black frame around the large soft grey pick rollers on the upper part of the paperfeed until it locks into place. Power off scanner and back on and the trya will lift and the paper will feed.
Posted on Jan 07, 2008
mohanchennai
  • 490 Answers
SOURCE: scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Posted on Mar 18, 2008
SOURCE: Load Paper in Feeder Error Message
i had this problem b-4, sometimes you have to turn the printer on and off seceral times befor it works. if you go to your trouble shooting under printer problems you take like a survey to find the problem. was it on when there was a storm? sometimes that can cause an error in the system to. sometimes you just have to repeat over and over w/ turning the computer and printer on and off several times until it works. good luck!!!
Posted on Jun 24, 2008
mohanchennai
  • 490 Answers
SOURCE: Scanned Image is all black
Try uninstalling and reinstall the scanner again. Try on a different computer. If even after this the problem remains, may be the there is some hardware fault (failure of light) in the scanner. How is it in color?
S. Mohan
Posted on Apr 09, 2009
mohanchennai
  • 490 Answers
SOURCE: dr-2050c multi-page document stops
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Posted on Jun 13, 2009
How do I take apart the HP Photosmart 8150 my kid put something in the chip feeder
The page feeder.....try looking where the object is inside the page feeder and try removing it with some nidle nose pliers but if its inside more into the page feeder it should be able to pop open
Jul 12, 2014 | Computers & Internet
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Feeder Issue
Open up the feeder, remove the two large chrome screws holding the beige cover and lift off. make sure nothing is blocking the rollers or switches. Further disassembly requires a Kyocera or Copystar technician.
Apr 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon DR-9080C Path-Through Scanner Logo
150 people viewed this question
old marine
old marine
