Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whilpool cabrio wtw5500xwo isn't moving the clothes around in the basket
Was there a recall on the cabrio model number WTW5500XWO
Hi
... this link may be helpful, did not immediately found the model you mentioned, but it is a very long page ...
Cheers.
https://www.consumeraffairs.com/whirlpool-maytag-washing-machine-and-dishwasher-recalls
May 04, 2017 | Washing Machines
CABRIO WTW5500XWO
Make sure that the water is turned on. Carefully under the main control panel if you lift it up when the water should be on you should hear the water inlet solenoids clicking on then off, if not make sure that the wires are connected UNPLUG FIRST BEFORE TOUCHING ANY WIRES
Dec 28, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
Sep 05, 2012 | Whirlpool WTW6400SW Cabrio Washer
Water is leaking from my washing machine when I am washing clothes and I keep getting the LD error code and UL but it is not unbalanced.
Grab hold of the inner basket & pull up & down. Does it move up & down? If not clothing is stuck between the inner & outer basket. Tilt the unit back & use a flash light & shine it through the clear plastic & see if you see clothes in it.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It throws a code oL it means over load and there's nothing it it but water so how can it be reset please
Tilt the unit back & shine a flash light through the clear inner basket & see if there is any clothing stuck in between the inner basket & outer basket. Open the lid & lift up on the inner basket It should move up & down.
Washer gives F50 error. I've taken top off and
Press pause cancel once and that should do it. If not the repair manual advises calling for service. Lets see what the F50 is...hold on...Motor stalled, rotor position sensor detects no motion from the tub, does basket move freely? If basket moves freely see test#3 in the repair manual HERE
The manual gives readings to verify and has a long detailed complicated set of IF's for this machine. Good luck
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio 6600sw2 has lots of problems, it stops and flashes F50 over and over again, it also flashes many of the other codes, it doesn't fill with enough water and it is not washing the clothes...
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Jan 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
