Question about Toshiba Televison & Video
Front panel button access
I have a toshiba 36a43 with the dreaded ''menu-keeps-popping-up'' problem. it was suggested to unsolder the menu button o the front panel. how difficult is it to remove the back panel? is it just a matter of removing the screws? Once i get the back off, are the front panel buttons easily accessible?
thanx in advance!
  • Donavan C Jun 23, 2009
    OK, got the back panel off, no problem. however, getting to the MENU button has proven to be a major PITA!!! There are tiny black boxes (i'm guessign they are the actual switches) that are behind each button on the front panel. I've tried my best to move the box (switch) that is for the MENU but i cannot move it.
    Can i just break that thing off or what? this is my only TV and it's killing me being without something to watch!!
  • Donavan C Jul 02, 2009
    Do these switches have to be soldered onto the board?
  • 668 Answers
You would be better off replacing all the switches on the front panel with Part # 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this Helps,
Skyassoc
Posted on Jul 02, 2009
Non-responsive to remote, acts like it is in constant menu mode, keeps cycling thru video input by itself or demo mode. Any solutions would be much appreciated!!
Your TV needs servicing.You need to open up the control panel and check the buttons for "menu". maybe its stuck inside.some contact cleaner would do the trick. Change the buttons if possible.
If symptoms persists than your control IC in the front panel is faulty and needs replacing.
Good luck and thanks for using FIXYA.
G..
Sep 24, 2011 | Toshiba 36A43 36" TV
My toshiba 36af42 the demo and menu will show up on the tv as if someone is pushing the buttons but there are not and i also took off the buttons off the board but still the same
Try replacing the jungle IC in the front of the board just before the control panel.
Your IC is faulty and will continue to give you this problem unless it is been replaced.
Good luck.
G..
Jun 29, 2011 | Toshiba 36A43 36" TV
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
Dec 13, 2009 | Toshiba 36A43 36" TV
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive.
The problem is most likely a short in the switch panel on the front of the TV. The remote won't work because the TV thinks that you are using the manual buttons on the front, and the manual buttons override the remote. Have the front button panel replaced....it's under $200.00 - or you could solder the switches apart and just use the remote.
Nov 01, 2009 | Toshiba 36A43 36" TV
Rca r56wh78
The menu btton itself on the front of the set is defective.
1. Have it replaced.
2. Remove the board and unsolder this button.
3. Unplug the front button board.
May 25, 2009 | RCA R52WH76 Television
Menu keep popping up
the button is shorted, unsolder the button and take it out. you can use the remote to use the menu if you want, you can also buy a new switch from radio shack.
Oct 28, 2008 | Toshiba 32A32 32" TV
Toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Jun 10, 2008 | Toshiba 36A43 36" TV
Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Oct 28, 2007 | Toshiba 36A43 36" TV
36a43 volume goes up and down buy itself
I had the same problem with my 36A43 also. I found by pure accident that if I pushed and held the MENU button on the front of the TV that the volume quit going up and down and I could control the volume with the remote. So far it is working all I did was jam 2 or 3 tooth-picks in beside the MENU button to hold it in and it is working so if this helps you any good luck its a cheap fix for an old TV
Oct 12, 2007 | Toshiba 36A43 36" TV
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Televison & Video Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
