Question about Encore Math Advantage Algebra II and Geometry 2.0 Full Version for PC
What is the surface area formula for triangular prism?
2 Suggested Answers
  • 132 Answers
SOURCE: what is the formula for getting the surface area
Surface area of any prism is the sum of the areas of the sides
A trapezium is A = h(a + b)/2
h is the perpendicular height, a and b are the parallel sides
Posted on Aug 18, 2011
Rectangular prism is made from centimeter cubes. What are the dimensions of the prism width x length x height? What is the surface area of the prism? What is the volume of the prism?
Dimension of the prism is the number of cubes in width x length x height.
Surface area is 2(w x l) + 2(l x h) + 2 (wxh)
Volume is the number of cubes.
Good luck,
Paul
Dec 07, 2016 | Office Equipment & Supplies
How do i do volume and surface area of triangular prism on ixl
Hello Jacqueline;
My name Peter. I am a engineering college graduate. Later I changed careers and now, I am a retired field service appliance technician. So, I work on the side and it you have any appliances that need repair call me @ 414306-1362.
The length on one side of the end triangle is "a"
The area of the end triangle is: (a x a) x 0.433 = Surface Area
The surface area of the prism face = a x length.
The volume is: The surface area of the end x the surface area of the face.
Mar 06, 2015 | ixl.com
How do i work out the volume of prisms mymaths task
Presuming this is a triangular prism, just get the area of triangle and then multiply by the length of the prism. So, 1/2 * B * H of triangle times the L (length) of prism.
Oct 28, 2014 | Office Equipment & Supplies
What is the rectangular prism total surface formula
Note the prism has Length, Width, Height
A = 2( WL + WH + LH )
May 23, 2014 | Computers & Internet
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Mar 29, 2014 | Office Equipment & Supplies
What is the surface area and volume for 14ft 12ft 3ft?
If that is a right rectangular prism
Volume =14*12*3 c.f.
For the area here is the formula.
Total area of right rectangular prism =2*A_b +P_b*h
A_b= area of base (take 14*12 feet squares)
P_b is perimeter of base (14+12)*2 =52 ft.
h is the height (3 ft)
Lateral area =P_b*h=52*3 feet square
Add all areas.
Mar 05, 2013 | SoftMath Algebrator - Algebra Homework...
Surface area of a rectangular prism whose length is 7 cm.,width is 4 cm., and thickness is 5 cm.?
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
  • surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
  • surface area = 2LW + 2(L+W)H
  • = 2 * 7 * 4 + 2*(7+4)*5
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Sep 05, 2011 | Encore Math Advantage Algebra II and...
What is the formula for getting the surface area of a trapezoidal prism?
Aug 10, 2011 | Encore Math Advantage Algebra II and...
What is rectangular prism?
Hello
Rectangular Prism/Cuboid Definition:
A Rectangular Prism/Cuboid is a solid figure bounded by six rectangular faces, a rectangular box. All angles are right angles, and opposite faces of a cuboid are equal. It is also a right rectangular prism.
Rectangular Prism/Cuboid Formula:
Area of Base(A) = l * w
Perimeter of Base(P) = 2l + 2w
Surface Area of Prism = 2(lw) + (2l + 2w)h = 2A + Ph
Volume of Prism = lwh = Ah
Diagonal of Prism = Sqrt(l² + w² + h²)
where
l = length, w = width, h = height
Hope this helps, if so do rate the solution
Jan 15, 2011 | MathRescue Word Problems Of Algebra Lite
Excel formula
the formulae for the surface area of round disc is
pi * r * r
where pi=3.14 and r =radious of disc= diametre/2
for this 1st u have 2 calculate the radious of the disc that is
180/2=90mm
then convert it to  m by dividing 1000 ,so radious=90/1000=0.09 m
finally calculate the area= 3.14 * 0.09 * 0.09=0.025434 sq metres
for 38 disc multiply 38 with the above area that is
0.025434 * 38=0.966492 sq metres
in excel 2007  u can do it more easily by going 2 formulas tab.
Under formla tab click on engineering formula and  then convert
here u can convert from mm to m
after converting use the above formula i just told u.
Feb 27, 2008 | Computers & Internet
Encore Math Advantage Algebra II and Geometry 2.0 Full Version for PC  Logo
32 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
